Broken Bolt...Argh!!! - JeepForum.com
post #1 of 16 Old 04-26-2015, 12:39 PM Thread Starter
boone
2003 WJ
Hi Guys,
I was working on changing the thermostat on my 2003 WJ with a 4.7L when the bottom bolt for the thermostat housing broke off. I have nothing to grab onto with a Vice-Grips since the bolt broke off inside of the block. Check out the pic. Any ideas as to the best way to get myself out of this mess?
boone is offline
post #2 of 16 Old 04-26-2015, 12:46 PM
mr312712
mr312712's Avatar
2008 WK
Drill It out but your probably gonna mess up the threads.
It doesn't matter If the guy next to you doesn't know your racing winning Is winning.
Castrol Edge 10W30 Full Synthetic
04 WJ Overland Inferno Red 4.7 MAGNUM V8 HIGH OUTPUT
mr312712 is offline
post #3 of 16 Old 04-26-2015, 12:58 PM
JMZ101586
Have two choices
Femove the rad and everything else in front and drill it out
Or
Remove the timing cover and drill it out Unless you have an angle drill and VERY good hands drilling without taking stuff out is gonna be damn near impossible.
On the plus side at least the lower bolt goes all through the housing. The upper doesn't.
04 WJ SE 4.7 Powertech
98 Camaro SLP SS
06 Pontiac GTO
20 WK2 Overland 5.7 Hemi
JMZ101586 is offline
post #4 of 16 Old 04-26-2015, 01:02 PM Thread Starter
boone
2003 WJ
Thanks guys. Sounds like I'll be doing some drilling. The radiator is out already. So, at least that part is done.
boone is offline
post #5 of 16 Old 04-27-2015, 11:06 PM
HVACNY
HVACNY's Avatar
2013 WK
Im feeling your pain.My bolt head snapped off the outer cover.let us know how it turns out.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #6 of 16 Old 04-28-2015, 06:38 AM
MadderThanMax
Get Some PB Blaster down there & let it soak, then apply a little heat and you may be lucky that it comes out when applying the drill to it. Hopefully you have a drill that can change to anti clockwise and it it just "may" unscrew what's left...
MadderThanMax is offline
post #7 of 16 Old 04-29-2015, 08:56 AM Thread Starter
boone
2003 WJ
I have some left hand drill bits coming on Friday. We'll see how things go.
boone is offline
post #8 of 16 Old 04-29-2015, 11:41 AM
Double E
Double E's Avatar
On the back side, can you dremel-grind a line into the housing that also reaches the bolt and allows you to turn it out like a screw?
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #9 of 16 Old 04-29-2015, 12:12 PM
new2site
new2site's Avatar
Autozone has USED kits you can "buy" and then return for full refund...their policy...the "buy" part is apparently because people put down stolen/ fake credit card for collateral.
http://www.autozone.com/test-scan-an...bolt-extractor
new2site is offline
post #10 of 16 Old 04-29-2015, 03:42 PM
doityourselfMM
doityourselfMM's Avatar
How did it snap? From over torqueing? The reason I ask is, I wonder if it will turn freely, or if it is binding? If it turned freely, put a small dab of JB Weld on the end of another bolt, push them together, and let it harden overnight. Obviously, using too much JB could cause it to ooze into the threads. I'd even push a small piece of rubber tubing into the hole to keep the cement out of the threads. The rubber tube would help to keep the outer bolt in place while the cement hardens.
Crazy idea, I know!
doityourselfMM is offline
post #11 of 16 Old 05-17-2015, 06:13 PM Thread Starter
boone
2003 WJ
After tying everything under the sun to get this broken bolt out, I finally just had to bite the bullet and replace the timing chain cover. I picked up a used one on eBay for $65.00. I hope that I can save someone some pain with this little tip. If you are going to replace your thermostat, spray some PB Blaster in the little hole that the lower housing bolt threads into on the back of the timing cover. I don't know why Chrysler designed it this way but that open hole just leaves a way for moisture to get in there and freeze up the bolt.
boone is offline
post #12 of 16 Old 05-18-2015, 09:42 AM
Cleaner13
I will say this, after changing mine out recently, that housing is only like 8ft/lbs of torque to tighten
2001 WJ Limited NV247 4.7
2008 WK Limited NV245 3.0 CRD
2003 Lexus Is300 2jz
Cleaner13 is offline
post #13 of 16 Old 05-18-2015, 10:02 AM
99WJ01TJ
For those uninitiated to the V8 thermostat bolt breaking(I was definitely in the club) the lower bolt will not easy out once its corroded in place. I tried even with the timing cover off. That's why I replaced mine when it snapped off, it was only $80 for a used timing cover. Would've run me about $40 to have a shop drill it ant re tap it.
99WJ01TJ is offline
post #14 of 16 Old 09-28-2017, 09:29 PM
Tumanyan
The old wound bleeding again!
I had a 01 GC 4.7, went trough this broken thermostat bolt crap years ago.
Now, on my "new" 04 Overland, servicing the cooling system, it's deja vu again.
The lower bolt, of course, again.
It was protruding about 1/4 or so, so i made a flat screwdriver slot in it with dremel.
Then i made the mating male part to it from grade 8 M6 bolt.
Another piece, a 1/2 long bushing with M6 tread inside was screwed over this two mating pieces
to insure they stay together, when torque applied to unscrew the broken part.
The broken bolt was just like fused/welded with that aluminum timing cover, because even soaking it
with PB blaster and DW40 overnight did nothing. It just broke again.
So, long story short, I took apart the front of the Jeep, drilled out the broken bolt,
run a M6 tap trough it, and put stainless bolts instead.
What a waste of time!
This is soo lame, instead of having bolts on the top and the bottom, they could place them on the sides, and the bottom bolt would not be in the harms way, like it is now.
Or just use stainless bolts.
I posted this, because someone else will go through this for sure, thanks to Chrysler, and I hope this helps.
And, yeah, having to deal with same problem twice, i needed to let the steam out:-)
Tumanyan is offline
post #15 of 16 Old 09-29-2017, 07:58 AM
Double E
Double E's Avatar
Amen brother. Maybe some anti-seize will help out too. I'm not looking forward to this repair on one of my WJs for certain. I might just spray it down now and at every oil change till I have to go after it some day.
Double E is offline
