Brakes stop the turn signals - JeepForum.com
 3Likes
post #1 of 18 Old 09-25-2021, 04:10 AM Thread Starter
GoatGuy
Chasing an answer to why the turn signals stop flashing when I press on the brake pedal. Also, when the brake pedal is pressed, both turn indicator's light up dimly to where you can see them at night. Any idea which direction I can go? It's a 04 Overland, if that makes a difference.
Mattimus_LV likes this.
GoatGuy is offline
post #2 of 18 Old 09-25-2021, 06:17 AM
Delta0
Have you checked your relevant earths / grounds yet G?
Bigrigr likes this.
Delta0 is offline
post #3 of 18 Old 09-25-2021, 08:43 AM Thread Starter
GoatGuy
Just got home from work and that's where I was going to start. Going to start opening things up after I finish chores and a snack.
GoatGuy is offline
post #4 of 18 Old 09-25-2021, 05:32 PM
Bigrigr
Bigrigr's Avatar
Agree with Delta here, sounds like a bad ground somewhere. Double check the bulb holders in the rear lights . They are known to have bad connections that effect the turn signals. Just a place to start...
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #5 of 18 Old 09-27-2021, 11:01 AM
leadsled jeep
leadsled jeep's Avatar
“Jeep’ seems synonymous with “electrical problems”. I’ll never buy another. Stupid CanBus system and crappy copper alloys in the wires. Gggggrrrrr…….
For a WEAK and IGNORANT people, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #6 of 18 Old 09-27-2021, 07:14 PM
CraigMBAx
CraigMBAx's Avatar
Mercedes have the exact same problems and their owners don't complain.
The Merc techs have seen it a thousand times and just fix it and the customer expects to pay the bill. Same for the timing chain guides and a host of other things.
1999 WJ Limted - Ex Soccer Mom ride turned Rule 25 Compliant Bike Hauler
CraigMBAx is offline
post #7 of 18 Old 09-27-2021, 07:24 PM
WJ60
WJ60's Avatar
If you ever find a car or truck that never breaks down could you post here and let us know what it is.
CraigMBAx likes this.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #8 of 18 Old 09-28-2021, 12:59 AM
Delta0
Oh dear Lead, your mistress been playing you up has she?
Delta0 is offline
post #9 of 18 Old 09-28-2021, 01:07 AM
Delta0
As I remember, my first 2 jeeps never broke down WJ.
Delta0 is offline
post #10 of 18 Old 09-28-2021, 08:43 PM
Mattimus_LV
Mattimus_LV's Avatar
'04 Overland here with the similar problem.
Do you have aftermarket taillights or have you swapped any of the exterior bulbs over to led?
2004 WJ Overland
IG @touristy.as.fck
Mattimus_LV is offline
post #11 of 18 Old 10-01-2021, 01:02 PM
leadsled jeep
Lol good one. Nope. Had 7 yes seven AC head units, a rear driver side window that rolls down on its own intermittently out of the blue. Replaced all window motor systems, replaced the wires in the door-body grommets due to cracked copper crap alloy they used. He’ll I have 100k more miles on my Lexus and I’ve replaced one window motor only. Nothing else electrical. I just replaced the alternator (yes OEM original) at 310k miles!!
Mechanically I LUV the WJ. Electrically mine SUXs. Baaaaaaad. Inexcusable.
post #12 of 18 Old 10-01-2021, 01:03 PM
leadsled jeep
Durned duplicate post.
post #13 of 18 Old 10-01-2021, 01:11 PM
CraigMBAx
CraigMBAx's Avatar
May I suggest you get a different 4wd next time?
Maybe this will help.
https://www.toyotanation.com/forums/4runner-forum.266/
post #14 of 18 Old 10-01-2021, 01:45 PM Thread Starter
GoatGuy
I've got both aftermarket LED headlights and taillights. I switched out the flasher relay when I installed them and everything seemed to work fine to start. When I use the flashers, without the brakes, they work great. It's only when I apply the brakes do they stop flashing.
GoatGuy is offline
post #15 of 18 Old 10-02-2021, 09:46 AM
Golden-Arm
Golden-Arm's Avatar
my tj has over 150k miles, and has never had anything other than fluid and filter changes, and I bought it new in 2002. i’ve never even had a flat tire with it.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
