LinkBack | Thread Tools |
Sponsored Links | |||
drive a mile, coast to a stop,no brakes. good brakes are cold. touch to find dragging one or more.
could be hoses plugged.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
Change the brake hose, they can collapse on the inside and look fine on the outside
Sent using Tapatalk
Sent using Tapatalk
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
If replacing the brake hoses, it is a good time to upgrade to stainless steel braided lines. Can get extended ones too. Most say they aren't needed, but with my adjustable front lowers, my brake hoses are pretty close to being taut. Haven't swapped hoses yet but bought a Goodridge kit, 4-15008, which comes with the four caliper hoses. There are other part numbers for the kit, 2-15008 and 15008, signifying the extension of the hoses. There is a fifth hose, the body to rear axle hose, which is not in the kit. Contacted Goodridge and they said they would look into it (doubt anything will change). So bought the body to rear axle hose from Clayton Offroad, COR-1300101. Clayton has the front caliper hoses but does not list rear caliper hoses. That is why I got the Goodridge kit for the caliper hoses.
Originally Posted by Oktavius
View Post
does wj have 2 rear hoses AND an axel hose?
my xj has one hose in back and metal tubing on the axel.
its raining so i didnt go look at wj! and lazy...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
First easy step is take all the brakes apart and make sure everything is clean, then bolt everything back together but use some washers to pack out the lug nuts so the rotors are held on tight without the wheels, then rotate them by hand to see/feel where its rubbing and go from there.
Originally Posted by 2oldjeeps
View Post
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
