LinkBack | Thread Tools |
Bought my son a 2003 WJ Friday
147K miles, 2WD, seems to be in VG condition as far as motor and transmission. A/C blows COLD (for now).
The left turn signal does not work. The right didn't either, but started working. I ordered a new turn signal switch to install. Also, the front right shock makes noise, so I will replace front shocks.
Because I'm lazy, what is the recommended oil?
Sponsored Links | |||
Turn signal could be the flasher relay. There is also a circuit board in the tail lamp that could need replacing.
Sent from my Pixel 3 XL using Tapatalk
Originally Posted by 007matman
View Post
Originally Posted by Micallen
View Post
Yeah, I can get a relay locally, so thought I'd try the switch first. Didn't know about the circuit board in the tail lamp though.
Does the Hazzard flashers work?
This is the circuit board
Dorman 923-036 Tail Lamp Circuit Board https://www.amazon.com/dp/B00ARUTX24..._oVt5DbV87ET0V
+1 on the relay being the issue. Most common and easiest of the likely causes to swap too.
4.0L I assume?
http://www.wjjeeps.com/service/maint..._wj.htm#ENGOIL
Synthetic is preferred by most of us. I just noticed wjjeeps says 10/30 for the HO. I've been using 5/30 in my WJs for decades and have not had issue.
Read the buyer's guide for what else to look for as issues...
4.0L I assume?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Originally Posted by Double E
View Post
4.0L I assume?
4.0L I assume?
View Post
I assumed if one side was still working, the relay might be OK. That's the other reason I went with switch first.
If you get a chance, read up on the way that the relay fails and you'll see why we recommended changing it first.
There's an entire 25+ response thread on the topic with pics. Googling the issue returns a dozen more threads on this and other sites for the same conclusion.
View Post
View Post
I have read up on it, but I thought when the relay failed, both sides failed. My right turn signal still works.
Verify the flasher is the problem...next time it flakes out on you, wiggle the flasher relay to see the behavior change. Before I re-floated the solder, I could bump that panel with my big toe while driving and it would work correctly.
Under a magnifying glass, i could easily see the solder cracks as in the images.
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
