Bolt for Bumper - JeepForum.com
post #1 of 4 Old 02-15-2020, 06:10 PM Thread Starter
TastyWheatLoaf
TastyWheatLoaf's Avatar
Bolt for Bumper
Well, it's official, one of the two bolts that zip into the quarter panel doesn't want to stay. Any idea of what to do? Anyone know the size of it, maybe screw in a size bigger one? Put a nut on the top, even thought it's a tight *** space to fit anything there?
TastyWheatLoaf is offline
post #2 of 4 Old 02-15-2020, 09:03 PM
Bigrigr
Bigrigr's Avatar
Which bumper? Front? or rear?
You mean one of the two bolts on the side of the rear bumper where it meets the rear wheel well?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,3"BBfront,2"BBrear,JK'sW/32's
Bigrigr is offline
post #3 of 4 Old 02-15-2020, 09:11 PM Thread Starter
TastyWheatLoaf
Front sorry should have specified
post #4 of 4 Old 02-17-2020, 01:15 AM
Bigrigr
Bigrigr's Avatar
I only know of one bolt in the very corner of the bumper cover on each side on the front. Then there are some screws in the grill area, and some panel clips underneath the Radiator support. If you are talking about the bolts in the corners, you can remove the inner fender liner by just popping out some panel clips and get right to the back side of that bolt. There is a Riv-nut there(or something similar). If it is stripped out, perhaps you can pop the rivnut out and just use a new bolt and lock nut up there to get it tight. Then just replace the inner fender liner and your good to go.
Bigrigr is offline
