Blue Hen - JeepForum.com
 1Likes
  • 1 Post By Jeeples
post #1 of 8 Old 05-14-2019, 09:08 AM Thread Starter
328driver
Blue Hen
Hi guys and gals. I recently had my keys stolen along with the fob. I installed a new immobilizer module along with a matching PCM and transponder key. Everything works except the oil pressure gauge. The donor car was a 2002. Mine is a 2004. Does that matter? Thanks.
328driver is offline
post #2 of 8 Old 05-15-2019, 09:03 PM
Mattyjm
Mattyjm's Avatar
Try a new Oil Pressure Sending Unit in your 2004 engine. It's cheap and easy to change if you're handy. Don't overtighten it! I got one from AdvanceAuto, a BWD sensor, which is OEM recommended, and has performed as expected ever since.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #3 of 8 Old 05-15-2019, 09:12 PM
Mattyjm
Mattyjm's Avatar
Herein lies another question to be pondered, discussed, and argued by WJ owners. My 2002 WJ 4.0L i6s' oil pressure gauge fluctuates CONSTANTLY when I'm driving it.
It is of popular opinion that the '02 models didn't come with a real gauge, but I think that mine did. My 2004 WJ, same powertrain, NEVER moves after start-up....it's more like a "dummy-gauge"....so if there's some pressure, the '04 reads that there's the same pressure as having a little pressure,
So, if you have an '04, having a little means the same as having a lot. I love my '02 because it constantly tells me how much I actually have
Mattyjm is offline
post #4 of 8 Old 05-15-2019, 10:33 PM
2oldjeeps
i think gauges read actual pressure,not on/off but variable.
i have three 4.0 and one 4.7. they all read actual,slight change from idle to running on road, 40 to 50...but solid at given speed.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #5 of 8 Old 05-16-2019, 07:59 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
'02 the change to the 'dummy' gauge was made, however depending on production date there are some '02's out there with the older style gauge. It's a single wire unit that simply displays whether or not the sensor is detecting oil pressure.
'99-'01 utilized a 2 wire sensor that will provide actual pressure readings. You'll note that this change coincides with the changes made to the gauge clusters...older style sending units will have gauge clusters with numbers on them, whereas the newer style sending units simply have an 'H' or an 'L' displayed.
jayheats likes this.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by Jeeples
This is easily the worst post, and thread, I have ever seen in 7 years of being on JF.
Jeeples is offline
post #6 of 8 Old 05-16-2019, 08:16 AM
Double E
Double E's Avatar
If the gauge is fluctuating and reads low with a cold engine, that's normally a sign the sending unit needs to be changed. They'll do that or they will start leaking, or both. Changing it is super easy.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 8 Old 05-16-2019, 10:32 AM
2oldjeeps
never saw an "h" , "l" but my 04,4.7 has one wire sender with regular real gage.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #8 of 8 Old 05-17-2019, 03:07 PM Thread Starter
328driver
So would a 2002 pcm not be compatible with an 04 sending unit if it was a different style oil sending unit? It was showing pressure before I swapped out the pcm. Or could it just be a coincidence?
Blue Driver? RockyWK WK Grand Cherokee & XK Commander Forum 2 04-15-2019 01:30 PM
Wanted: Jeep CJ-7 blue roll bar cover and console Rotorhead Wanted 0 08-05-2018 09:27 PM
'03 4.7 - Blowing blue smoke lcsfletcher WJ Grand Cherokee Forum 4 07-23-2018 09:28 AM
Anyone use the blue devil oil stop leak or rear main fix 97jeepxj1 WJ Grand Cherokee Forum 5 06-08-2018 02:43 PM
Blue Best Top for CJ5. What's it worth? herpman Jeep CJ Forum 3 12-29-2017 06:55 AM
