blower motor stuck on? - JeepForum.com
post #1 of 6 Old 09-15-2010, 10:11 PM Thread Starter
Howiedooit
I've had to pull the blower motor relay on my 99 wj because the blower will not turn off, even when the indicator is in the off position. I haven't had time to diagnose the prob, however I was hoping someone may have had a similar prob and could save me some hastle. any thoughts? thanks
Howiedooit is offline
post #2 of 6 Old 09-15-2010, 11:08 PM
steves99wj
Try a new relay, it could be that the one you have is blown and is just letting the current run through
steves99wj is offline
post #3 of 6 Old 09-15-2010, 11:15 PM
Falkon
Bad blower motor resistor?
http://www.wjjeeps.com/blower_motor.htm
Falkon is offline
post #4 of 6 Old 03-02-2012, 10:28 PM
koivula
Hi Howiedooit,
Did you get any cure for your blower not stopping? Just yesterday I run into the same kind of problem with my '00 WJ. Blower is all the time at full speed and wont stop even with removing ignition key? Is killing battery in a couple of hours... Any one elsehaving this kind of problem?
BR Timo
koivula is offline
post #5 of 6 Old 03-03-2012, 07:50 AM
HVACNY
HVACNY's Avatar
2013 WK
Originally Posted by koivula
Hihttp://jeepspace.jeepforum.com/Howiedooit Howiedooit,
BR Timo
It probably melted the wires in the on position,check the resistor under the glove box area,very common issue.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #6 of 6 Old 03-19-2012, 03:58 AM
koivula
Hi,
yep, that was the problem in my case too, thanks for the tip.
BR Timo
koivula is offline
Trail fix for Blower Motor Resistor narnwv WJ Grand Cherokee Forum 4 08-22-2010 04:49 PM
Intermittent Blower Motor Madmike4790 WJ Grand Cherokee Forum 11 08-21-2010 05:58 PM
Lost my Blower motor ScotZ WJ Grand Cherokee Forum 2 06-23-2010 08:42 PM
99 WJ blower motor will not run Go4Lo WJ Grand Cherokee Forum 11 06-01-2010 09:28 PM
02 overland blower motor cuts in and out platinum5.9 WJ Grand Cherokee Forum 4 02-03-2009 09:00 PM
