Blower motor resistor upgrade - JeepForum.com
post #1 of 10 Old 04-07-2014, 05:45 PM Thread Starter
RepomanNC
2001 WJ with 4.7 heat and AC blower motor stopped working. I took the resistor off and I have the typical melted connector. I purchased the new upgraded resistor and wiring kit to fix it. Here is where my question begins. I've read in several places the wiring harness supplied that runs from the resistor to the blower motor is wired incorrectly, that you need to pull the blue piece on the connector and swap the wires. My dumb question is, do I swap them on one end of the harness, or both ends? If I swap them on both end wouldn't I be back where I started? As always thanks for you response in advance
RepomanNC is offline
post #2 of 10 Old 04-07-2014, 06:10 PM
rdkendrick
2003 WJ
As far as I know, if you replace the whole blower resistor with the new one (with the bigger fins) you just reverse the wires that connect to it. If you don't, it will run backwards.
Sent from my iPad using electrons
rdkendrick is offline
post #3 of 10 Old 04-07-2014, 08:06 PM
cr8zynelly
cr8zynelly's Avatar
One end.
cr8zynelly is offline
post #4 of 10 Old 04-07-2014, 08:45 PM
reneveah
2003 WJ
Wrote up on this? Where do u buy this newer one with bigger fins?
03 Jeep WJ Overland>
91 Ford Taurus>
reneveah is offline
post #5 of 10 Old 04-07-2014, 09:44 PM
cr8zynelly
cr8zynelly's Avatar
http://bit.ly/1hyzrqG
post #6 of 10 Old 04-08-2014, 06:20 AM Thread Starter
RepomanNC
I purchased the one with the bigger fins from Amazon along with the new wiring harness.
Thanks for all the replies!!
post #7 of 10 Old 04-08-2014, 04:48 PM
reneveah
2003 WJ
Is there a write up to wiring this right? I see everyone saying u have to switch the wires
91 Ford Taurus>
reneveah is offline
post #8 of 10 Old 04-08-2014, 05:29 PM
jziegler
You switch the two wires that go from resistor to the blower motor. I believe one is black and one is green. Just cut and swap.
2002 wj limited 4.7 h.o.265/70/17 hankook dynapro atm 4in rough country lift, adjustible track bar, rough country steering stabilizer.
jziegler is offline
post #9 of 10 Old 04-09-2014, 11:50 AM
miami5th
If you buy the Mopar kit with the upgraded resistor you have to swap the wire orientation coming from the resistor to the blower motor. I believe it's a green and black wire set. I just focused on the plug that goes into the blower motor. No need to slice and splice to change the wire orientation. Examine the plug and you'll see some clips that are easily removed that allows you to just pull out the black/green wires from the plug and re-install them.
I had to do this on my resistor upgrade. Except I didn't realize the wiring was backwards until I noticed the fan spinning in the wrong direction and a drastic loss in air flow. Swapping the black/green wires fixed the problem.
miami5th is offline
post #10 of 10 Old 04-09-2014, 06:33 PM Thread Starter
RepomanNC
You just look square at the end you will see a blue clip, remove that, remove the two wires, swap them, put them back in and put the blue clip back in.
