Best way to reinstall trans cooler lines to radiator ? - JeepForum.com
post #1 of 4 Old 10-22-2021, 08:47 PM Thread Starter
Rylxmp
2003 WJ
Hi there, I am switching my radiator out on my 2003 jeep WJ 4.7 and need some help on what is the best way to reinstall the trans cooler lines that you screw on to the radiator. I have read that if I don't make them tight enough they'll leak and if I over tighten them then they'll strip and leak and that I have to remove the radiator again to tighten them up if I don't get it right the first time. Is it a good idea to use blue loctite on the receiving end threads and then tighten them up with a 7/8 wrench until they cant tighten at all anymore? thanks
Rylxmp is offline
post #2 of 4 Old 10-23-2021, 02:39 PM
cDee63
cDee63's Avatar
They are a flare seal, no need to gorilla torque them or put loctite on them. You DO have to hold the hex on the fitting while tightening up the line to it, and make sure the flare surface on both fitting and line are clean.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #3 of 4 Old 10-25-2021, 08:42 AM
Double E
Double E's Avatar
...or dump that integrated radiator system and get an external cooler, mount it in front of the radiator. Cheap & easier than connecting the OEM stuff up.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #4 of 4 Old 10-25-2021, 08:57 AM
cDee63
cDee63's Avatar
What Mr. Double E said. This is the best solution.
cDee63 is offline
