Best shocks for a WJ?!? - Page 3 - JeepForum.com
 7Likes
post #31 of 56 Old 04-25-2013, 03:06 PM
RIPNBST
I've got KYB Monomaxx and have less than $200 in all four and they ride great.
RIPNBST is offline
post #32 of 56 Old 03-28-2018, 12:58 PM
Videojam
Videojam's Avatar
Just ordered a set of 4600's from Kolak - really excited to feel the difference
Believe I have the stock OEM's pushing 190k miles
Videojam is offline
post #33 of 56 Old 03-28-2018, 02:10 PM
NicksWj
Please do yourself a favor and don't purchase skyjackers. I purchased them and the shock itself has rusted in about a month and the bushing are noisy. I contacted customer service and they said it is not covered under warranty....
NicksWj is offline
post #34 of 56 Old 09-14-2021, 02:52 PM
Videojam
Videojam's Avatar
Bumping an old thread - over 3 years and 40k miles later and I'm still loving the billy's
Mattyjm likes this.
Videojam is offline
post #35 of 56 Old 09-14-2021, 03:43 PM
cDee63
cDee63's Avatar
I'll add to the old thread. Have only been running the Billies for a couple months, several people who ridden in it before commented on how much better it rides.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #36 of 56 Old 09-14-2021, 04:57 PM
snowbuggy
That's what we like to hear.
snowbuggy is offline
post #37 of 56 Old 09-14-2021, 06:59 PM
carlsondrew3
Junior Member
carlsondrew3's Avatar
To chime in as well, I run some Fox 2.0ís and Iíve loved them dearly. Smooth on pavement and amazingly responsive off-road.
snowbuggy likes this.
2004 WJ 4.0L - "Jordan"
2.5" Lift, Rusty's Front Springs, BDS Rear Springs, FOX 2.0 BDS IFP,
IRO Custom Double Cardan Front Driveshaft
Check it out on RevKit and Instagram:
carlsondrew3 is offline
post #38 of 56 Old 09-15-2021, 02:39 AM
Delta0
I understand that gas shocks give a harder / firmer / bumpier / sportier ride than normal shocks.
On the other hand, normal shocks give a smoother / softer / gentler / comfortabler ride
Delta0 is offline
post #39 of 56 Old 09-15-2021, 03:17 AM
Kolak
Vendor
Kolak's Avatar
There's two types of gas shocks - low and high pressure. Either one can ride great or ride stiff/firm depending upon how they're valved.
High pressure shocks have an advantage of better fade resistance and more rapid responsiveness but they're more expensive than low pressure.
Bilstein makes generally very comfortable riding high pressure shocks. You gotta be careful with some of the low pressure shocks out there though - there's a lot of them that are valved stiffly.
Originally Posted by Delta0 View Post
I understand that gas shocks give a harder /firmer / bumpier / sportier ride than normal shocks.
Delta0 likes this.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #40 of 56 Old 09-15-2021, 04:05 AM
Delta0
How do we tell if we are buying soft ride gas shocks or bump stop ride shocks please Kolak?
The last set of Bilsteins I fitted rode like we were riding on the bump stops.
Delta0 is offline
post #41 of 56 Old 09-15-2021, 05:21 PM
Kolak
Vendor
Kolak's Avatar
Perhaps they were the incorrect lengths for your Jeep.
Delta0 likes this.
or
Kolak is offline
post #42 of 56 Old 09-16-2021, 11:57 PM
Delta0
Thanks Kolak.
Delta0 is offline
post #43 of 56 Old 09-25-2021, 04:23 PM
Bigrigr
Bigrigr's Avatar
Bilstien 5100's all the way....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #44 of 56 Old 09-27-2021, 03:49 PM
willis36
willis36's Avatar
I normally hate anything Rancho, but the RS5000x shocks are wonderful. Replaced my Bilsteins with them and ohhh the difference. I guess I have an opposing opinion to most on here, I absolutely can not stand the way any Bilstein rides. They handle big hits good, but will destroy your kidneys driving over tooth picks.
skain8 likes this.
willis36 is offline
post #45 of 56 Old 09-30-2021, 12:59 AM
BigMateo
To add to a pretty much dead thread, I've had kyb excel-gs. they were ok for a factory replacement. I loved my bilstein 5100's, they rode and handled great, but I was severely disappointed with how my jeep handled cargo in the rear. Just adding a couple hundred pounds caused the rear end to squat more than I would have liked, not really anything to do with the shock and more with the coil spring I was running at the time. If I get another Grand, I will probably see if I can find a decent set of air shocks for the rear that will be long enough for a lift, and still probably run a set of 5100's for the front. I've had air shocks in the past on other cars and really liked the ability to raise and lower the rear and make it stiffer or softer with just a schrader valve.
BigMateo is offline
