Best fender trim approach. - JeepForum.com
 2Likes
  • 2 Post By ArtemDar
post #1 of 3 Old 05-12-2021, 07:13 PM Thread Starter
ArtemDar
Hi Guys,
Finished lift and long arm package - now its time to make real offroad not "mall crawler" jeep.
Any advice on approach how to trim? Tons of videos on youtube but what best based on your experience?
Artem
CJREX and SocalJeeper21 like this.
ArtemDar is offline
post #2 of 3 Old 05-13-2021, 07:50 AM
CJREX
CJREX's Avatar
With tires extending that far I'd do the Bushwackers.
2004 GC Overland 4.7 HO
Powerful Wanderer (wife named it after driving it)
265/70/17 MT, 2" BDS lift
CJREX is offline
post #3 of 3 Old 05-13-2021, 10:34 PM
Bigrigr
Bigrigr's Avatar
I take an inside line at the bottom of the front bumper that is 2" in front of the factory edge, then angle it back to the top of the bumper cover where it attaches to the fender. Remove that same 2 " straight across the bottom until you get to the thin metal bracket ears where the bumper cover attaches with the plastic clips under the radiator. Trim the inner fender liner up a small amount until you have just enough left to drill a hole through the liner and a little metal tab that is hiding just above the fog lights. then install a plastic clip to hold the liner in place. If you cut it straight enough, 90% of the people who look at it wont even notice you did it. Minimal backspacing on the wheels, or 1 1/2" spacers or less will keep the tire from hitting the back of the front fender, however, you may be able to cheat that a bit if your lower control arms are adjustable(I assume yours are with longarms). If you still hit the fog lights, then you have to do the foglight delete. (I had to, but I didnt want to at first, now Im good with it) On the back, I just "rolled" the inside lip of the fender well all the way around. Now the tire just slips inside of it at full stuff. This part required paint and body work, but it was less than what will be needed if you trim the metal like most others do. Extended bumptops helped when I didnt want to hack into the rockers front and rear.(this is where it gets real ugly)
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
