Best cold weather battery - JeepForum.com
 1Likes
post #1 of 30 Old 07-25-2020, 02:34 PM Thread Starter
Hipmusicman
It's time to get a new battery!
I live in a place where the temps. will get to as low as - 40F during winter mornings. Last year we reached right around - 60F for a day or 2. A bit abnormal but the year before that was similar. I understand nearly nothing mechanical or electrical is truly meant to survive that but it's the reality of my location sometimes.
I'm leaning towards either Diehard or Odyssey AGM batteries. However, I'm not convinced they are any better or worse in cold climates vs. lead acid.
I've already watched project farm's video on a few batteries so no need to post that. I'd rather hear some personal experiences
Any thoughts?
Hipmusicman is offline
post #2 of 30 Old 07-25-2020, 02:38 PM
ravenworks
ravenworks's Avatar
Anything made in the USA that is in the top teir of their products.
I have a Northstar that I love but it's also a $380 battery.
Deka makes good stuff
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 30 Old 07-25-2020, 03:09 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You want the largetst Cold Cranking Amps (CCA) rated battery that will fit. For Minnesota winters I get the best and biggest NAPA battery for my vehicles. Cheap batteries are cheap for reason. A block heater or oil pan heater makes the starting much easier and helps get the passenger cabin warm sooner.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 30 Old 07-25-2020, 03:21 PM Thread Starter
Hipmusicman
I did have a block heater for a while. Went through 3 of them and 5 re-installs between them to discovering they don't sit deep enough in the block to make a good enough seal. Any ideas there would be cool.
In terms of batteries, price is little object for me.
How many CCAs do you see in the batteries you get?
post #5 of 30 Old 07-25-2020, 03:30 PM
ravenworks
ravenworks's Avatar
My Northstar has over 1100 CCA
Anything that is 850 would make you a happy camper.
Buy your battery local from a dealer that sells nothing but automotive electrical equipment, such as batteries and starters.
Don't be afraid to find a heavy truck or equipment dealer to get you a good USA made battery.
This is the one I have it has one of the best warranties in the business
https://www.northstarbattery.com/product/nsb-agm31
Semper-Fi "81-84"
I.U.O.E. - 18
post #6 of 30 Old 07-25-2020, 04:13 PM Thread Starter
Hipmusicman
http://www.northstarbattery.com/product/nsb-agm31
Maybe I should be more specific on the "price is little object" statement lol. $400 seems pretty steep for a battery. However, if the value is truly there, I'm all for it. Just seems a bit much for what you get.
post #7 of 30 Old 07-25-2020, 04:21 PM
rjbruzan
The NorthStar was about $250 at Batteries + 6 months ago.
Rubicon has a new one and the WJs is over 7 years old.
If you have Farm and Fleet near you the Duration AGM is also good. I put a new one in the dune Jeep only cause it was 7 years old and is now doing duty in the motorhomes house battery. About $160
I am sold on AGMs.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #8 of 30 Old 07-25-2020, 04:24 PM
99wjtx
99wjtx's Avatar
For $380 hopefully you get assault too. Fortunately, I'm not into that sort of thing.
Really, you'd be well-served with a dual battery setup. You could have a switching mechanism and basically double your CCA as needed or simply run the second battery as a spare.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #9 of 30 Old 07-25-2020, 04:44 PM Thread Starter
Hipmusicman
Dual battery is a plan in the future. I need to work on a number of other things first. Plus, I don't have the accessories that would really call for it. Not to mention where I would put the second one though I have some pretty good ideas. Everything I install, I want to look factory. Tough to do with somethings but as close as I can get.
I have a fleet and a farm near me (fleet farm &#x1f60b I'll do a little research there.
What was the $250 Northstar exactly?
post #10 of 30 Old 07-25-2020, 04:49 PM
Bigrigr
Bigrigr's Avatar
Ravenworks has a good point, Most semi truck batteries are designed to take abuse. If your worried about starting your Jeep in those temps, thing about those poor suckers with Semi trucks trying to do the same. Anyone that has experience with Semi Truck batteries will know how to get a good one. Maybe a 380.00 battery isnt needed, but I have bought alot of batteries over the years with 1000CCAs for 100-150.00(even 200 bucks wouldnt be outrageous) bucks a piece. Granted they are paired up, or even tripled up at times, but im betting that one would spin that WJ over easily. Just need one with the correct physical dims...
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #11 of 30 Old 07-25-2020, 05:37 PM Thread Starter
Hipmusicman
So looking a little bit more at Northstar, I found NSB-AGM65 which seems comparable to Odyssey's 65-PC1750T.
Is it really worth finding something higher than 900-some CCA?
post #12 of 30 Old 07-25-2020, 06:16 PM
speednjay
speednjay's Avatar
I’m from Wisconsin and I always had good luck with fitting the biggest battery I had room for, even if I had to put a bigger tray in. Something around 1000cca. Then it was finding a reliable battery with a good Warranty. Costco .. sams club usually had the best one. But keeping your car really maintained will pull more weight than the biggest battery you can find. Put in high quality Synthetic oils, fresh spark plugs, wires, grounds,...etc
speednjay is offline
post #13 of 30 Old 07-25-2020, 06:19 PM
Bigrigr
Bigrigr's Avatar
Only if you count on the extra as reserve when its cold.(which i do). I cant remember the exact math, but there is a formula that shows the CCA loss at low temperatures. It's something like a 800CCA battery becomes more like a 600CCA battery below 0 degrees(something similar) So....If you get the biggest battery you can possibly fit, you will still be more likely to start your Jeep at the lowest temps.
Bigrigr is offline
post #14 of 30 Old 07-25-2020, 06:30 PM Thread Starter
Hipmusicman
So with possibly wanting a little more CCA in mind, it seems we are down to group size that actually fits the WJ. Without fitting a different tray, what have we been able to fit? 65 is stock.
I can do a new tray if I absolutely need to but I really don't think I need to be going that far in terms of effort.
post #15 of 30 Old 07-25-2020, 07:30 PM
xcaliber81
xcaliber81's Avatar
I'm using a Kirkland battery. We also get cold winters and you can also run a battery blanket.
I currently am only using an oil pan heater and its been that way about a year now and just that got me through almost a week of -50 all by itself.
xcaliber81 is offline
