Backwards oil pressure after replacing sending unit? - JeepForum.com
post #1 of 11 Old 12-11-2008, 07:52 PM Thread Starter
gonzo350
2001 Grand Cherokee 4.7 After a few minutes of driving and the engine fully came up to temp my oil pressure (per the gauge) would drop to zero at idle after only a few seconds and then come back up to normal pressure once I resumed driving. Oil pressure sending unit right? Replaced the sending unit and now I have the opposite problem! Normal pressure at idle, drop to zero when driving! No strange noises, oil level is full, no leaks....no idea!? Thoughts?
gonzo350 is offline
post #2 of 11 Old 12-11-2008, 08:12 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Return the sender to where you purchased it and get a replacement.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 11 Old 12-11-2008, 08:19 PM Thread Starter
gonzo350
LOL I would, but it was the last one in stock, and of course they're closed now. Think its just a bad unit?
gonzo350 is offline
post #4 of 11 Old 12-11-2008, 08:52 PM
elmer_fud
elmer_fud's Avatar
wrong sensor
take it back, and take the old one with you or copy any numbers you can down any numbers you can find
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #5 of 11 Old 01-24-2010, 11:52 AM
jeepfixer
Same Problem
I have the same exact problem with my 01 GC Limited 4.7 Difference is I put in 2 new sending units and they don't fix the problem. I even confirmed the latest new one at NAPA with the parts guy via the computer and the book. I am now thinking it is a faulty gauge in the cluster but any other ideas prior to ripping out the dash would be helpful.
jeepfixer is offline
post #6 of 11 Old 04-19-2010, 11:05 PM
tlakael13
Hi, y'all. I was having the same problem on my 01 GC Lmt 4.7; sometimes it would to zero and then back up to normal...then, it stopped doing it for a while....a year later, it came back....two weeks ago,I replaced the unit, but it continued doing the same thing until two days ago....it now stays a zero. I checked the oil level, and it is OK. There is no weird noise, and it sounds good. How much should I tighten the unit? Maybe I over did it. I already have 191K miles on it. Do I have to take in for a rebuild? Well, thanks for this great forum and its members; it has helped me out many times. I appreciate the help and time.
tlakael13 is offline
post #7 of 11 Old 04-20-2010, 01:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Stop buying parts store senders. More often then not they don't agree with jeeps. Mopar only.
ratmonkey is offline
post #8 of 11 Old 04-20-2010, 09:09 AM
LordHobbit
LordHobbit's Avatar
That's your problem. I've never had good parts or good service or good prices at NAPA.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #9 of 11 Old 12-17-2010, 11:02 AM
autoposer
Having the same problem. After replacing with NAPA sending unit pressure drops to 0 with acceleration. Old one only dropped to 0 at idle every once and a while. Did anyone here have success when changing back to the Mopar brand?
autoposer is offline
post #10 of 11 Old 12-17-2010, 03:39 PM
narnwv
narnwv's Avatar
x2 NAPA sucks. I've never got anything from them for any vehicle that was worth a crap.
~Aaron
narnwv is offline
post #11 of 11 Old 12-17-2010, 03:43 PM
autoposer
In case anyone else stumbles across this thread, I too just proved that Napa sucks. I purchased 3 oil sending units from them. One snapped off at the post and the other two caused my oil pressure to go backwards after install. I finally went and purchased a Mopar one for 300% more money but its now working great...
Oil Pressure Sending Unit??? filipm ZJ Grand Cherokee Forum 3 07-19-2009 10:08 PM
Oil pressure sending unit sinbad85 ZJ Grand Cherokee Forum 13 01-07-2009 08:45 PM
oil pressure sending unit JeePing21 ZJ Grand Cherokee Forum 3 08-25-2006 03:37 PM
hi! oil pressure sending unit help. fallingsux ZJ Grand Cherokee Forum 2 01-29-2006 11:07 PM
Replacing Fuel Sending Unit asutherl ZJ Grand Cherokee Forum 6 06-30-2004 04:08 PM
