AZC rebuild. - JeepForum.com
post #1 of 23 Old 08-12-2019, 03:57 PM Thread Starter
xcaliber81
xcaliber81's Avatar
AZC rebuild.
Looking at redoing my blend doors and such with the metal ones ill link. I see there are mode doors as well I am wondering do I need to include those as well if I am doing everything else?
Or can the mode doors be done after?
http://blendorstore.com/home
xcaliber81 is offline
post #2 of 23 Old 08-12-2019, 05:16 PM
99wjtx
99wjtx's Avatar
Other than the actuator which you can reach near the driver side heater outlet, I believe the mode section is inaccessible without pulling the HVAC box.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #3 of 23 Old 08-13-2019, 12:12 AM
Uniblurb
Uniblurb's Avatar
While one of the actuators/motors is accessible on the driver's side box to actually change any mode doors the dash is going to need to be removed. You can see further in that blendorstore link where they mention this with every mode door. And below is the mode door set.
http://blendorstore.com/--
When I end up pulling my box I'll end up ordering the above or find a mode door set along with the recirc door too. I've already changed out the dual-control blend doors.
One thing I'm going to make sure I change out is the passenger side blend door actuator which is on the back of the box towards the firewall. Mine was acting a little wonky before and I don't need to pull the box again just to change it out.
This actuator on the firewall-side of the box is identical/same part number as the one for the driver's side blend door on the front of the box. May pay a little more but I'll be going with Mopar for the blend door actuator like below.
https://www.ebay.com/itm/Jeep-Grand-...-/183203197595
Some may just stay with their current one. Good luck xcaliber.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #4 of 23 Old 08-13-2019, 05:30 AM Thread Starter
xcaliber81
xcaliber81's Avatar
Uniblurb do you know of 3 actuators? 2 for the blend doors and 1 for the recirculation door? I'm going to do the works and I dont want to short change myself. Kolak says the parts book says 4 actuators but I can think of 3
post #5 of 23 Old 08-13-2019, 09:35 AM
jtpeters
Mode Door Motor/Actuator
Driver Blend Door Motor/Actuator
Passenger Blend Door Motor/Actuator
Recirculation Door Motor/Actuator
2004 Jeep Overland WJ 4.7 H.O. (Bought new in Oct 2003)
2014 Jeep Overland WK2 5.7 Hemi (Bought used in 2016 w/7k miles)
1970 Ford Mustang Boss 302 (in Family since 1974)
2013 Ford Mustang Boss 302
2011 BMW 328i
jtpeters is offline
post #6 of 23 Old 08-13-2019, 12:37 PM
Uniblurb
Uniblurb's Avatar
^ Yep. Excaliber, You may want to look at the HVAC box diagram I just posted in another below thread. Also read the last 2 lines I wrote above the diagram along with CarlJH's good post following mine where he found the Mopar AC drain seal (OE 5012696AA) still available.
https://www.jeepforum.com/forum/f310.../#post40705367
In rebuilding the box I'd replace all foam seals in that diagram including the below ones which fit around the heater core & evaporator tubes while pressing up against the inner firewall:
Seal, AC evaporator, 5014 744AA
Seal, Heater tubes, 5012 744AA
You may want to check with Kolak to see if he can still find these.
Also when I do my box I'm going to replace all the foam seals for the vents as Harry outlined in his real good write-up below.
https://www.jeepforum.com/forum/f310...vents-3544698/
Uniblurb is offline
post #7 of 23 Old 08-13-2019, 01:21 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Thank you guys.
post #8 of 23 Old 08-13-2019, 01:42 PM
Cirruslydakota
Im in the middle of doing this right now.
Sent from my LM-G710VM using Tapatalk
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #9 of 23 Old 08-13-2019, 01:49 PM Thread Starter
xcaliber81
xcaliber81's Avatar
oh perfect timing I am in the middle of purchasing everything. feel free and do a mini write up here if you feel
post #10 of 23 Old 08-14-2019, 12:07 AM
Cirruslydakota
I would have but its already back together and sitting on my kitchen table. Waiting on three door servo motors that should be here tomorrow. I had a broken drive on my recirc motor. All blend doors were intact and working fine.
Bear - 99 WJ Laredo
post #11 of 23 Old 11-01-2019, 07:01 PM Thread Starter
xcaliber81
xcaliber81's Avatar
I have my dash out and the HVAC apart right now. I am wondering how do I clean my evaporator coils or can I?
I am not replacing either as they work and still look in good shape.
When assembling the new aluminum doors to the HVAC box do I need to use some type of lube on contact points?
post #12 of 23 Old 11-01-2019, 07:36 PM
99wjtx
99wjtx's Avatar
There's a product sold in aerosol cans at hardware stores and home improvement warehouses called "coil cleaner". It's commonly used to clean the coils of home AC evaporators.
A long-lasting, plastic-safe lube like white lithium would probably be a good idea on any contact points that move.
99wjtx is offline
post #13 of 23 Old 11-01-2019, 10:34 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Awesome thanks. Just spent a few hours cleaning out the HVAC box, pretty gross.
post #14 of 23 Old 11-03-2019, 11:07 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Got it in everything works fantastic and no more codes, its so smooth and I can't even hear it operate anymore.
I took some orange nail polish and painted the pnrd tab back to orange too lol.
20191101_132942[1].jpg   20191102_154033[1].jpg   20191103_153539[1].jpg   20191103_165356[1].jpg
post #15 of 23 Old 11-10-2019, 10:07 PM Thread Starter
xcaliber81
xcaliber81's Avatar
I got my coolant bled (hopefully) checked every setting seems to change to every mode. On my center vent it blows strange, it blows hard to the left side of the drivers side and the rest is mediocre. I should try another calibration 1st.
