Any tips on changing the coil springs? - JeepForum.com
 1Likes
  • 1 Post By Mattyjm
post #1 of 13 Old 04-10-2019, 04:25 PM Thread Starter
JGCJeep
The directions look pretty simple and straightforward. Any tips not included in the directions?
JGCJeep is offline
post #2 of 13 Old 04-10-2019, 04:52 PM
AVR2
Don't know what the directions say, but the safest way to change the coil springs is to remove the calipers, disconnect the track bar, driveshaft and sway bar links, and lower the axle until the springs are free.
AVR2 is offline
post #3 of 13 Old 04-10-2019, 06:17 PM
Mattyjm
Mattyjm's Avatar
I removed my shocks and sway bar links. I did not remove or loosen any control arms or dive shafts. I don't think I removed my calipers. I had the whole Jeep up on jack stands. I used a floor jack to jack up one side far enough so that the other side would go down and release the spring. Installation is opposite of removal.
It was actually a lot easier than what I thought. No spring compressors were involved, either. I was working alone and wondered how violently the spring was going to release. Not at all, actually. They come out easy.
2000 Laredo. Now a donor vehicle to my
2002 Laredo. Baloo. Currently a work in progress.
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #4 of 13 Old 04-10-2019, 06:36 PM Thread Starter
JGCJeep
That’s pretty much what the directions say. 🙂 Thank you.
JGCJeep is offline
post #5 of 13 Old 04-10-2019, 09:10 PM
Mattyjm
Mattyjm's Avatar
I had it on jack stands on good sub frame points on a level concrete garage floor. Don't take that step lightly. A good friend lent four heavy duty jack stands to me in place of a lift. Safety is paramount when doing anything because if I'm injured or dead, I'm no good to my family AND I'll be injured OR dead, which is not how I want to be.
99sajeep likes this.
Mattyjm is offline
post #6 of 13 Old 04-10-2019, 11:05 PM
singletrack100
Replace all rubber isolators while doing the job. Also be prepared to find your front spring perches rotted- can be repaired.
singletrack100 is offline
post #7 of 13 Old 04-11-2019, 06:31 AM Thread Starter
JGCJeep
How does it get repaired?
JGCJeep is offline
post #8 of 13 Old 04-11-2019, 06:39 AM
singletrack100
JGCJeep, if your perches are rotted there are a few things that can be done. You can order replacement perch kits from Iron Rock Offroad or some other outfit and have them welded on. If your handy with metal work and welding you can clean up the area and replace with tubing of suitable size. All repairs removal of rusted/rotted material and welding new perches in. This is a common thing with WJ's so there's lot's of info online by searching.
post #9 of 13 Old 04-11-2019, 09:50 PM
sparky636
sparky636's Avatar
I have not had to remove calipers for front or rear. Are you lifting or just replacing factory?
-Jeepin aint easy-
sparky636 is offline
post #10 of 13 Old 04-12-2019, 01:27 AM
BigMateo
Newbie
Neither did I.
Just did this earlier today this earlier today in fact, I just loosened the shock, sway bar links, and took the track bar out since I'm replacing it anyways. Loosened the bolts on the lower control arms a little and they popped right out really easy. I didn't even need a spring compressor to get my new taller springs back in either.
BigMateo is offline
post #11 of 13 Old 04-12-2019, 04:18 AM Thread Starter
JGCJeep
Just replacing.
JGCJeep is offline
post #12 of 13 Old 04-12-2019, 04:19 AM Thread Starter
JGCJeep
Thanks for the info. 🙂
JGCJeep is offline
post #13 of 13 Old 04-12-2019, 04:56 AM
AVR2
Originally Posted by BigMateo View Post
Neither did I.
It's a very long time since I did it, and I had vague memories of removing the calipers because otherwise the brake hoses prevented the axle drooping enough to let the top of the springs come completely clear of the frame.
The real takeaway is that you simply need to disconnect enough to let the axle droop to the point where the springs are slowly and safely released without any need to screw around with compressors.
AVR2 is offline
I-6 'TeamRush Upgrade' (definitive) JeepHammer Jeep CJ Forum 788 03-21-2019 09:20 AM
Which coil springs? williambmac TJ Wrangler Technical Forum 39 10-27-2018 01:46 PM
Coil Springs Awesome YJ Wrangler Technical Forum 17 10-03-2018 08:04 PM
Chasing Gremlins Nereussailor Jeep CJ Forum 11 09-01-2018 05:41 AM
Jeep sitting lopsided after replacing coil springs. Bzwth WK Grand Cherokee & XK Commander Forum 12 08-07-2018 07:15 PM
