Anticipating Crankshaft Sensor Failure - JeepForum.com
 9Likes
post #1 of 19 Old 09-13-2021, 03:01 AM Thread Starter
Delta0
Risk assessment.
From what I read, crankshaft sensors often fail.
Mine's an '03 with less then 75,000 miles on the clock.
I expect to drive less than 5,000 miles year.
Whilst the plague stalks the country, I daresay I'll drive a lot less than 3,000.
Should I have a spare sensor in the car just in case please?
I live in Merry Old England so importing a just in case OEM sensor would cost me silly money.
Should I get a local cheapo to keep me going just while I import an OEM please?
What are the chances of a cheapo getting me around while I bring an OEM in from the States please?
What are the options I've missed please?
Thanks.
Delta0 is offline
post #2 of 19 Old 09-13-2021, 04:37 AM
Darnice
I have 300,000 miles on my original cps, so no worry i would say. You can always have it scaned and see if there have been any cps issues in diagnostics if your that concerned. What engine do you have?
Delta0 likes this.
Darnice is offline
post #3 of 19 Old 09-13-2021, 06:02 AM
snowbuggy
We only hear about the bad ones here. We don't hear about the millions that never have trouble.
Delta0 likes this.
snowbuggy is offline
post #4 of 19 Old 09-13-2021, 06:09 AM
cDee63
cDee63's Avatar
As much of a PITA it is changing no matter what the engine, I would not put a generic in. I believe you have an HO 4.7? Changing the sensor on that requires dropping the starter as well and to make things even more fun mine was stuck in the hole, I had to thread a screw into the broken off body to get it out of the block. I will add it was changed only because I was changing the starter anyway and figured while I was down there I would do it as well not knowing the history of the rig, it was working fine until I got a hold of it...
Delta0 likes this.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #5 of 19 Old 09-13-2021, 12:32 PM Thread Starter
Delta0
Thanks Darnice, your 300,000 miles is good news.
A 4.7 HO.
As far as I can tell, it's always been treated gently.
Delta0 is offline
post #6 of 19 Old 09-13-2021, 12:55 PM Thread Starter
Delta0
Thanks Snowy, that's an excellent point.
And very comforting too.
Delta0 is offline
post #7 of 19 Old 09-13-2021, 01:25 PM Thread Starter
Delta0
Thanks for the warning about the job being a PITA on an HO.
If it lets me down, I'll get someone with a lift to do it for me.
Thanks for the pic of the broken bit with a screw sticking out.
Thanks also your your advice to avoid a generic.
Delta0 is offline
post #8 of 19 Old 09-13-2021, 10:54 PM
Uniblurb
Uniblurb's Avatar
Agree with cDee and I wouldn't waste my money on an aftermarket crank sensor. Whether you have the HO or regular 4.7 the crank sensor is going to be the same. Your 03 4.7 HO uses the same Mopar 56028666AB crank sensor my 04 4.7 (reg) w/120K miles uses.
I bought a spare a few years ago and just don't be shocked when you see the Mopar 56028666AB crank sensor is now made in China. And that's not just because it's being sold by Amazon since you'll see the same sensor from the dealer.
The crank sensor packaging can be seen on the left side of the below link.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Reviews are all over the board...
Of all the crank sensors I've seen go bad it was almost always where the ground and power circuits bled together inside the sensor when it went bad. Same is true for brand new sensors I purchased from a local parts store for one of my 4.0 Jeeps and there was resistance between the power & ground cavity pins when there should be none.
Reason I used my ohm meter on the new Mopar 5602666AB crank sensor as soon as I bought it. I didn't even open the package and just poked 2 small holes in the package with my meter probes while it tested good using the below chart procedure.
Your choice if you want a spare crank sensor or not Delta0 and good luck.
Delta0 likes this.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #9 of 19 Old 09-14-2021, 03:51 AM Thread Starter
Delta0
Thank you very much Uni.
I've spent a long time learning from your post.
I find it excellent advice and information, especially the about how to test a crankshaft sensor.
I'm not in the least surprised to find Mopar have their parts made in China.
I learnt long ago that the Chinese are so slick with their manufacture that the same factory will make good, bad, or downright ugly CPSs, batteries, can openers, whatever depending on what the buyer wants.
And then there's the CPSs that go out the back door.
Delta0 is offline
post #10 of 19 Old 09-14-2021, 09:39 PM
Uniblurb
Uniblurb's Avatar
No problem Delta0 and glad the post helps.
Delta0 likes this.
Uniblurb is offline
post #11 of 19 Old 09-16-2021, 01:18 PM
leadsled jeep
leadsled jeep's Avatar
I was curious when I read the title of this thread. Especially with 235k miles on my 4.7HO. All’s well here on my OEM sensor as well.
Delta0 likes this.
For a WEAK and IGNORANT people, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #12 of 19 Old 09-17-2021, 10:45 AM Thread Starter
Delta0
Originally Posted by leadsled jeep View Post
I was curious when I read the title of this thread. Especially with 235k miles on my 4.7HO. Allís well here on my OEM sensor as well.
Thank you very much lead, your good news is very comforting
Delta0 is offline
post #13 of 19 Old 09-17-2021, 11:31 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
The CPS on the 4.0 is located where there is little air flow. Heat kills sensors. Due to low mileage you have been dodging a bullet but it will eventually fail. Mine failed at about double the miles you have. That said I recommend you find an OEM sensor before it's too late as they are discontinuing parts for WJs, that's what it comes down to. You don't want to get in a situation where all you have available is an aftermarket part that you'll need to replace every other year because it's garbage. Replacement a CPS on a 4.0 WJ is NOT fun.
Delta0 likes this.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
2020 RECOUNT
rep-tile is offline
post #14 of 19 Old 09-18-2021, 12:38 AM Thread Starter
Delta0
Thank you very much Rep, a very interesting point of view.
Delta0 is offline
post #15 of 19 Old 09-19-2021, 10:50 AM
blueseasons1
For as much time I spend on this forum and WJ FB pages. I have not become aware that they fail "often". Being a critical component and one that the vehicle will not operate without. I replace it and the crank sensor right after I buy a WJ. I own 2. A HO 4.7 and a non HO 4.7. I pay a mechanic to install them. A little over $250 (USA) with OEM parts and labor. Cheap insurance from my perspective. I keep the old sensors. So if you are really worried about it failing swap it out before and you will likely not need to worry about it. Not something "easily" done on the side of the road. I could have done it myself but the OEM sensors are relatively expensive. The labor being the lessor expense so rather than risk having the cam sensor break off. I splurged.
Delta0 likes this.
blueseasons1 is offline
