Am I missing anything......??? - JeepForum.com
post #1 of 39 Old 09-12-2017, 07:29 PM Thread Starter
GhostJeepWJ
GhostJeepWJ's Avatar
Arrow Am I missing anything......???
(Such a rehashed subject...lol)
Next Project on deck is to redo my ENTIRE HVAC system. I have the problems with the blend doors and the recir door. Since I have to pull the entire dash, the smart thing to do is replace EVERYTHING that's mechanical or moves.
Parts List - (Am I missing anything)
Blend Doors - 2
Recir Door - 1
Motor/actuator for all 3
Heater Core
Evaporator
Foam (to replace all the decayed vent seals)
Missing anything? Or any other recommendations?....
It's not the Destination so much as the Journey!! - Cpt. Jack Sparrow
2002 Grand Cherokee Overland 4.7 HO
2" IRO Spring Lift w/Bilstein 5100s 245/75/R17 Goodyear Armour Shield
GhostJeepWJ is offline
post #2 of 39 Old 09-12-2017, 08:10 PM
cmurphy034
Also your mode door actuator, so a total of 4 actuators
2001 WJ Limited 87k miles
4.0 Straight Six
42RE Transmission
NV 247 Quadradrive
cmurphy034 is offline
post #3 of 39 Old 09-12-2017, 08:36 PM Thread Starter
GhostJeepWJ
Ahhh ha! See, knew I would miss something..lol! Thanks @cmurphy034
Thinking I might see if Kolak can get all these parts.
post #4 of 39 Old 09-12-2017, 08:47 PM
cmurphy034
Yeah, he's a good source for mopar parts. Good luck with the job
4.0 Straight Six
42RE Transmission
NV 247 Quadradrive
post #5 of 39 Old 09-12-2017, 09:03 PM Thread Starter
GhostJeepWJ
10+ plus hours I'm estimating. Gonna replace clock spring while it's out. Finally get rid of that pesky Airbag light!
@Kolak can you fill this shopping list for me?
post #6 of 39 Old 09-13-2017, 06:51 AM
NeedBoost
you might want new hoses for the heater core and maybe a new thermostat.
NeedBoost is offline
post #7 of 39 Old 09-13-2017, 06:08 PM Thread Starter
GhostJeepWJ
Yea!! not a bad idea!! I'll replace the ones that lead from the heater core.
As for the thermostat, that's a repair for later. I tried to replace it when I flushed the coolant a few months back. But, one of the bolts was seized up. Running out of time I elected to save it for later. Didn't want to get stuck if the bolt broke. Spring time I'm diving into that plus replacing all the hoses under the hood with Silicone hoses.
post #8 of 39 Old 10-17-2017, 06:52 PM Thread Starter
GhostJeepWJ
How many hoses in there for the heater core? 4 I believe.....
How's everyone feel about replacing the AC Evap? Is it necessary? I heard they last forever, but not sure how true that is
Hoses for Heater Core....
Heater to Pipe 1
Pipe 1 to the engine
Heater to Pipe 2
Pipe 2 to engine
There may be a 5th one?......
post #9 of 39 Old 10-17-2017, 06:54 PM
cmurphy034
2 hoses for the heater core, they will be very hard to get off, I ended up cutting the ends to relieve some pressure. And for the amount of $ it costs to replace the evaporator, I would, you don't want to be doing this job more than once
4.0 Straight Six
42RE Transmission
NV 247 Quadradrive
post #10 of 39 Old 10-17-2017, 07:38 PM Thread Starter
GhostJeepWJ
Yea that was my initial thought as well.
I'll sell the Jeep before I take that dash out again!....lol
post #11 of 39 Old 10-18-2017, 06:04 AM
HarryH3
Look closer and you'll find that there are actually FOUR hoses. Don't forget the other end of the metal lines that go across the valve cover, to the water pump. The rubber at that end should be replaced also. The ends are crimped from the factory but you can just cut the crimp, replace the rubber and install hose clamps.
HarryH3 is offline
post #12 of 39 Old 10-18-2017, 06:38 AM
tybarious
tybarious's Avatar
I have a problem with drainage in mine. I've done the blend door replace before and it didn't fix the drainage. I'm thinking of doing it again (going to replace the heater and ac cores and hoses as well), and was thinking I might try drilling out or somehow improving the drain. Do you have this issue?
tybarious is offline
post #13 of 39 Old 10-18-2017, 06:45 AM
xcaliber81
xcaliber81's Avatar
Will you be using oem or aftermarket? I will be doing the same as you soon I want to replace everything including my resistor and blower motor. I'm actually doing the blower motor this weekend but I also would like to add the hvac filter.
xcaliber81 is offline
post #14 of 39 Old 10-18-2017, 02:55 PM
NeedBoost
if you are doing the evaporator you may want to do the receiver dryer as well.
post #15 of 39 Old 10-18-2017, 06:49 PM Thread Starter
GhostJeepWJ
No, I haven't noticed any drainage problems. You're referring to AC drainage correct?
Some OEM (the door motors) then mostly aftermarket. But that depends. If I order directly from RockAuto. But I'm going to message Kolak see if he can get me a package together that would include EVERYTHING.
