Alarm will not go off!! - JeepForum.com
 1Likes
  • 1 Post By Curly48
post #1 of 15 Old 10-27-2021, 10:05 AM Thread Starter
frenemiller
I have a 2003 Jeep Grand cherokee. Skim removed, computer reprogrammed for skim removal. everything was fine until i unlocked the door with the key. Now the alarm will not go off. I have tried everything!! Can anybody help??!!
frenemiller is offline
post #2 of 15 Old 10-27-2021, 10:06 AM
leadsled jeep
leadsled jeep's Avatar
Have you disconnected the battery for 3min or so? Wonder if that’s help reset it?
For a WEAK and IGNORANT sheople, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #3 of 15 Old 10-27-2021, 02:36 PM
Delta0
I occasionally set the alarm off when I unlock.
I get the alarm to go off by locking, and then unlocking again carefully making sure I don't turn the key any further than necessary.
Delta0 is offline
post #4 of 15 Old 10-27-2021, 05:16 PM
steelo2525
Turn your key 3 times in your door, unlock-lock unlock-lock unlock-lock and unlock. This is how I have to get into car so alarm doesn't go off as my key fob doesn't work.
Sent from my Nokia 7.2 using Tapatalk
steelo2525 is offline
post #5 of 15 Old 10-28-2021, 02:06 AM
Delta0
Have you any idea why that trick works please Steelo?
Delta0 is offline
post #6 of 15 Old 10-28-2021, 03:15 AM
steelo2525
It's a back door in the programming, I was told about this on a forum here in Australia.
It's similar to the one to get codes to come up which I think is 9.
post #7 of 15 Old 10-28-2021, 08:05 AM
Delta0
Thanks, Steelo.
Delta0 is offline
post #8 of 15 Old 10-28-2021, 10:29 PM
Curly48
There is a "Driver Cylinder Lock Switch" located inside the Drivers Door. It is some kind of a Magnetic Core Switch that gets activated when your turn the key to unlock and lock the Drivers Door. My 2001 WJ is missing this Magnetic Core around the Cylinder. I'm wondering if that is why my Security System will not activate. But that's another project for another day. I've attached some pictures and a page of the Workshop Service Repair Manual below. Can anyone else shed some light on what kind of Magnetic Swith this is and how it actually works? My Jeep is the Red one in the Pictures, you can that the switch is missing. Also I show the Connector located under the Drivers Door Panel.
cDee63 likes this.
Curly48 is offline
post #9 of 15 Old 10-29-2021, 07:20 AM
cDee63
cDee63's Avatar
I have to try this, I do not have a fob as well and my alarm goes off everytime I unlock the door with the key.. To the point I rewired the horns to a momentary foot switch to keep them quiet, because driving without a horn in Detroit is impossible,lol.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #10 of 15 Old 10-29-2021, 10:40 AM Thread Starter
frenemiller
Unfortunately, this did not work! Is there anyway to disable the alarm completely? I have searched the web and cannot find anything. I find info on other models but not this particular one!
post #11 of 15 Old 10-29-2021, 10:42 AM Thread Starter
frenemiller
post #12 of 15 Old 10-29-2021, 11:31 AM
cDee63
cDee63's Avatar
That switch is, of course, another one of those discontinued parts... I found an article on how to take apart and clean one, apparently there are resistors in it each with a different resistance depending on lock cylinder position.
cDee63 is offline
post #13 of 15 Old 10-29-2021, 08:23 PM
wranglertec
Either there is an aftermarket alarm tied into the factory alarm system. You removed the skim module and had the pcm flashed to start and run without the skim. The BCM ( body control module) is not seeing a signal from the skim module since it was removed. It thinks the vehicle is being stolen. That vehicle uses a single wire pci buss communication system. The buss wire that is use to to send data the ever module in the vehicle. Iím not sure how to bypass the bcm. My fear is if you put the skim back in to see if the alarm goes off the pcm May relearn that vehicle has skim key.
Sent from my iPhone using Tapatalk
wranglertec is online now
post #14 of 15 Old 10-29-2021, 10:09 PM
cDee63
cDee63's Avatar
^^It will. At least it did on mine. Had SKIM disabled and mistakenly plugged the module back in, no more disabled SKIM.
cDee63 is offline
post #15 of 15 Old 10-30-2021, 06:43 PM
Curly48
You can eliminate the Door Cylinder Lock Switch by taking the Trim Panel off the Door and unplugging the Connector from the harness. The connector that I show in the picture of my previous post.
Curly48 is offline
