Aftermarket radio when I have the Infinity system/amp.. Is it a pain to install? - JeepForum.com
 1Likes
post #1 of 16 Old 05-21-2019, 05:14 PM Thread Starter
blastic
From what I remember I have read a lot about how it's a pain to hook up an aftermarket deck if you have the Infinity System/Amp is this true and if so what exactly has to be done to get everything working right?
rworden1 likes this.
blastic is offline
post #2 of 16 Old 05-21-2019, 05:30 PM
MrBaz
I would also like to know the answer to this. I have the Infinity system, but my head unit is failing.
2004 WJ, 4.7HO, 2 cats, magnaflow
MrBaz is offline
post #3 of 16 Old 05-21-2019, 05:48 PM
wjkeith
wjkeith's Avatar
Not hard at all
wjkeith is offline
post #4 of 16 Old 05-21-2019, 06:21 PM
xcaliber81
xcaliber81's Avatar
the only difference is the blue remote wire for the amp if you don't hook that up you will have no sound.
xcaliber81 is offline
post #5 of 16 Old 05-22-2019, 09:23 AM
scott_0
as said, it's super easy with the proper harness for your year, and again, as said, don't forget to wire up the remote amp turn on for the Infinity amp
Sent from my iPhone using Tapatalk
2002 GC Limited, all stock, undecided mods to come
scott_0 is offline
post #6 of 16 Old 05-22-2019, 09:25 AM
GmanWJ
GmanWJ's Avatar
If all you want to do is replace the head unit, this is a pretty simple repair. If you buy an aftermarket unit from Crutchfield, they will send you all the adapters and wiring harnesses that you need to get it done, and instructions. If you can solder a few wires together, this is no problem. If not, you can always crimp them together which may work well enough.
Some high power units want a new 10-gauge wire run directly to the battery, but if you are going to use the existing amp, then you should not need that kind of direct feed.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #7 of 16 Old 05-22-2019, 05:33 PM
Chris Radley
What about those of us that want to retain the steering wheel radio control buttons? Is a can bus adapter necessary in order to keep those functions?
If so does anyone recommend a brand/model #?
Chris Radley is offline
post #8 of 16 Old 05-22-2019, 07:23 PM
scott_0
you'll need one of these
https://www.crutchfield.com/p_120ASW...RoCBNMQAvD_BwE
scott_0 is offline
post #9 of 16 Old 05-22-2019, 10:36 PM
smokeyyank
I just did mine. Make sure to get the correct harness connect( it has the rca preouts) the blue wire for amp turn on and your good to go. If you move up to a double din be prepared for a level of wtf. Lots of cutting and cursing.
smokeyyank is offline
post #10 of 16 Old 05-23-2019, 02:34 AM
Fzz
You need the adaptor if the head unit cannot take the signal directly from the steering wheel control wire (which sends a negative varying voltage on the WJ) - But it should say that on the listing for each head unit what it needs anyway.
The irony is that the more expensive well known brands don't seem to be able to take the feed directly and need the adaptor, whereas the cheaper head units (like the Pumpkin one I have) can take the -ve feed straight from the steering wheel into the head unit.
Fzz is offline
post #11 of 16 Old 05-23-2019, 09:04 AM
MrBaz
Please, do explain (Pics?)
MrBaz is offline
post #12 of 16 Old 05-23-2019, 11:25 AM
GmanWJ
GmanWJ's Avatar
LOL yes, if you want to keep it simpler, use a single DIN unit. Double DIN is bigger and fancier and all, but it doesn't fit without trimming parts of the dash.
GmanWJ is offline
post #13 of 16 Old 05-24-2019, 05:36 PM Thread Starter
blastic
I give props to anyone that successfully installs a decent looking double din deck in their WJ. I definitely am not putting myself through that hell. Question though. For someone who isn't GREAT with this stuff, how hard is it to set up the steering wheel controls? I'm going with a single din from Crutchfield, if I opt for the steering wheel control setup will it come with specific how-to-for-dummy instructions?
blastic is offline
post #14 of 16 Old 05-24-2019, 06:05 PM Thread Starter
blastic
I hear a lot about the rear speakers not working after install. How did you avoid that from happening?
blastic is offline
post #15 of 16 Old 05-24-2019, 08:41 PM
scott_0
it's really not that bad, the wireless carplay makes it all worth it
scott_0 is offline
The Johnny 5 Build -Syntax- Jeep Builds 51 03-08-2019 10:25 AM
Aftermarket radio install Mike Huff Audio, CB & Ham Radios, GPS, & Electrical 2 12-28-2018 11:38 AM
Project "TripleF" - DirectMatrix's YJ Thread DirectMatrix YJ Wrangler Technical Forum 107 12-18-2018 10:33 AM
Infinity Sound System 95 ZJ with Kenwood radio. muddflow ZJ Grand Cherokee Forum 39 10-25-2018 09:54 AM
aftermarket radio install questions three_jeeps WJ Grand Cherokee Forum 8 05-16-2018 10:57 AM
