99 WJ blower motor will not run - JeepForum.com
post #1 of 12 Old 06-01-2010, 11:56 AM Thread Starter
Go4Lo
hey guys, I've been on here a while but haven't really posted anything of value, but was hoping for some help
My problem is that my blower motor for the air will not run. I pulled it out and it runs when connected to a battery. Everything cut out so I replaced the resistor, still not fixed. Anyone have any idea what could be wrong (the 40A fuse under the hood is brand new). I'm also getting power to the resistor and to the blower motor
Thanks in advance
Go4Lo is offline
post #2 of 12 Old 06-01-2010, 12:01 PM
nlynd1978
2006 XK Commander
did you check the havc control in the dash. My ford pick up had a similar problem that was fixed by replacing the controls.
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #3 of 12 Old 06-01-2010, 12:15 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you have dual zone climate control?
If so, have you pulled the codes from the system yet?
Wheelin98TJ is offline
post #4 of 12 Old 06-01-2010, 02:13 PM Thread Starter
Go4Lo
Ya I have the dual climate, and it's not showing any codes except the recirc door travel too large, which has been a problem since I have had it that I just dont need to fix it in my eyes
I pulled the dash control out, and it was getting power and seemed to be sending power back out
thanks for the replies!
Go4Lo is offline
post #5 of 12 Old 06-01-2010, 02:20 PM
Wheelin98TJ
JEEP FREAK
Your recirculation door probably fell down and its blocking the air flow completely.
I had a feeling this was your problem.
Here is more info:
https://www.jeepforum.com/forum/f13/w...x-pics-347814/
post #6 of 12 Old 06-01-2010, 02:22 PM Thread Starter
Go4Lo
but my recirc door has been broke for over a year now and hasnt caused a problem. shouldnt the blower fan at least be trying to kick on?
Go4Lo is offline
post #7 of 12 Old 06-01-2010, 02:41 PM
nlynd1978
2006 XK Commander
getting power is not the same as the switch working. you need to test the switch, also check for vacume leak.
post #8 of 12 Old 06-01-2010, 02:48 PM Thread Starter
Go4Lo
how can I tell if the switch is working?
where are the vacuum lines that may be leaking?
Go4Lo is offline
post #9 of 12 Old 06-01-2010, 03:07 PM
nlynd1978
2006 XK Commander
is the switch electronic or vacume
post #10 of 12 Old 06-01-2010, 03:27 PM Thread Starter
Go4Lo
im kind of new to all this, but from what I can see it's electronic. Are we talking the fan speed switch on the dash? I pulled it out and it's all wired, no vacuum lines...if that helps
Go4Lo is offline
post #11 of 12 Old 06-01-2010, 09:07 PM
Wheelin98TJ
JEEP FREAK
There is no vacuum on the dual zone systems. Its all electronic.
Did you see the info page on WJJeeps yet for diagnosing issues with the blower? If not, here is the link:
Jeep Grand Cherokee WJ - Blower motor connector repair
post #12 of 12 Old 06-01-2010, 09:28 PM Thread Starter
Go4Lo
Ya I've been through the checklist on that site...still can't find the problem. Maybe I'll go through it again tomorrow and make sure I didn't miss something. My blower fan works when hooked to a battery, but a mechanic friend thinks it's needing too much power to run and the system wont give it to it, . . . any thoughts on that?
Go4Lo is offline
blower motor - blower motor connector melted BradMB2004 ZJ Grand Cherokee Forum 9 10-14-2014 08:57 AM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 02:33 PM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 12:51 PM
Blower motor mdjst5 ZJ Grand Cherokee Forum 5 10-26-2008 08:58 AM
94 JGC, where is the blower motor relay, and where's the blower motor ground wire go? camosilver ZJ Grand Cherokee Forum 1 08-24-2006 10:15 PM
