LinkBack | Thread Tools |
99' WJ 4.0 242 swap 242HD
Since my TC is leaking on my 99' WJ 4.0 I was thinking of upgrading to the 242HD version from Ebay or similar.
Should this be a straight-forward swap, or is there something else I should know ?..Going to have my Mechanic install this.
Thanks, Joe
Thanks, Joe
Sponsored Links | |||
Search forum on this topic everything you need to know has been discussed. Cliff's notes version is the HD was meant for V8 so you need to swap input shaft and rear drive shaft may need to be modified. My personal recommendation unless you're wheeling it hard and have large tires there's no real reason to do this to a daily driver or weekend trail rig. Just go find a junkyard replacement to yours that's not leaking or fix yours. 3rd option let it leak gives you an excuse to check levels and add fresh fluid. That's the relationship I personally have with my transmission
Originally Posted by LuthWJ77
View Post
I believe several forum members run the standard non-HD 242 behind the V8 with no problems because it's considered strong enough with a good torque rating. So if that's the case then surely it's fine with the 4.0. Not only that, but they also have done it because it's easier to find and cheaper.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
Thanks for the information, guys, and will keep the standard 242 and get it fixed or just keep refilling it.
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
