99 WJ 4.0 204k idle 10psi oil pressure - JeepForum.com
post #1 of 8 Old 05-03-2021, 05:33 PM Thread Starter
tsetsaf
As the title describes. Bought as a mechanic special. Great jeep overall. Very clean and well maintained. No valve train or other noises.
Previous owner sold because the stock pressure gauge was tripping the gauge light. I installed a manual gauge and oil pressure drops to 10psi once really warm and driven.
Book says 13 psi for low end. I plan to pull the motor but want to push it a couple months before doing so. Oil pressure is fine with some throttle.
Changed oil to 5w40 plus Lucas oil stabilizer.
I have read many of the other posts on this topic and appreciate the combined wisdom hear within.
If you were to take a bet... how many more miles will I get out of this motor?
What are your thoughts?
tsetsaf is offline
post #2 of 8 Old 05-03-2021, 07:06 PM
jtec
jtec's Avatar
2014 JK Wrangler
try some hail marys, yes to the lucas, and 5w40, maybe a quality filter, add some RISOLONE maybe it frees up a oil bypass relief, let us know, but plan on a pump, gather the parts get a good work place pick the time - you don't need a hi volume.
jtec is offline
post #3 of 8 Old 05-03-2021, 07:47 PM
Caish
1987 XJ Cherokee
Low oil pressure at idle most of the time can be traced to worn cam bearings.
My old 258 in the YJ/CJ hybrid aka Halfbreed has 5 psi or less at idle, then lifters start ticking, but running down the road its 25 psi.
Generally as a rule you need 10 psi for every 1000 RPM...
Quit Facebook.
Gab: Jeepers
Mewe: Arkansas Jeeps
my stable:87 XJ, 2k WJ, 88 MJ, 91 YJ, 09 JK...
Caish is offline
post #4 of 8 Old 05-03-2021, 10:02 PM Thread Starter
tsetsaf
So is it simply a cause for ticking or will it kill the motor?
tsetsaf is offline
post #5 of 8 Old 05-04-2021, 04:30 PM
Caish
1987 XJ Cherokee
IF oil pressure is low enough the lifters are ticking, I would be concerned.
I would pull the oil pan and drop a rod cap, and Main Cap inspect the bearings, Not hard to change them, could get it back up, I would also check the clearance in the oil pump, could be just a weak, pump.
200k on a 4.0 if had regular oil changes wouldn't think bearings to be shot.
I have another question, when cold start, how bad does it rattle and how long before it quiets down?
But still thinking cam bearings.....
Quit Facebook.
Gab: Jeepers
Caish is offline
post #6 of 8 Old 05-04-2021, 05:03 PM
snowbuggy
I would run 15w40 in a loose engine. If I was still nervous I would run 50 wt racing oil until tear down time.
snowbuggy is offline
post #7 of 8 Old 05-04-2021, 08:40 PM
Golden-Arm
Golden-Arm's Avatar
this is right. if it was my motor, and i had oil pressure that low, i'd be running synthetic 30 weight, at the minimum. i'd put a good filter in it, as well, and i'd consider doing a flush with chemicals, before that 30 weight oil change. 50w works in the summer, it will be like tar come january though.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is online now
post #8 of 8 Old 05-04-2021, 10:40 PM Thread Starter
tsetsaf
Fires right up and pressure immediately goes to 45 psi. There is a minor mechanical sound but nothing pronounced and immediately gone when the pressure rises.
Thanks for the feedback everyone. I will take it easy until I can drop the pan. Will report back.
tsetsaf is offline
