99 GC Limited: Growling noise from rear while turning L/R low speed (sound included) - JeepForum.com
post #1 of 7 Old 12-07-2019, 10:02 AM Thread Starter
caliskier
Hi all,
My beloved 1999 grand cherokee limited makes a loud growling sound from the rear when I am driving in parking lots, especially when I am turning hard into a parking space. Reverse / Forward / Left / Right does not seam to matter, just a low loud growling sound at low speed while turning. Straight driving forward and reverse or turning at higher speeds I do not hear it. It sounds exactly like what you here in the included video... start it at 0.20
Anyone have experience with this issue?
caliskier is offline
post #2 of 7 Old 12-07-2019, 08:22 PM
rjbruzan
Limited slip in rear? Then it needs friction modifier.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 7 Old 12-07-2019, 09:36 PM Thread Starter
caliskier
Are you saying to drain and refill the rear dif?
http://www.wjjeeps.com/service/maint....htm#AIRFILTER
For heavy-duty or trailer tow use:
SAE 75W-140 synthetic
Moparģ P/N 04874469
NOTE: Trac-lok and Vari-lok equipped axles require 4 ounces of Limited Slip Additive be added to the lubricant.
post #4 of 7 Old 12-08-2019, 09:22 AM
rjbruzan
That may help get rid of the growling noise.
Ron
rjbruzan is offline
post #5 of 7 Old 12-09-2019, 07:12 PM
gsxr800
Needs the friction modifier. Maybe someone replaced the differential fluid and didnít add the additive? But that will definitely fix that noise.
Sent from my iPhone using Tapatalk
02 Grand Cherokee 4.0 w/IRO 4" lift, Bilstein 5100, Adj TB, Skid Plate, 17" JK Moab w/Falken A/T3W
gsxr800 is offline
post #6 of 7 Old 12-09-2019, 07:18 PM
gsxr800
gsxr800 is offline
post #7 of 7 Old 12-09-2019, 08:38 PM Thread Starter
caliskier
Thanks, yes it has a leak, I need to do the whole thing.
BTW, I don't know why this post split, I have two that say the same thing, i did not intend for that to happen.
