545 tranny taking much more fluid than expected after drain and fill - JeepForum.com
post #1 of 12 Old 08-10-2011, 03:39 PM Thread Starter
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
I just finished a drain and fill, and changed both filters on my 01 WJ's 545 transmission.
I expected the refill to take 6.5 qts....so I added 6.5 and ran the Jeep to bring it up to temp. I shifted through all of the gears and the level seemed fine at the time.
Then I drove maybe 50 miles after the fluid change and rechecked the level. It didn't even register on the stick. It took another 1.5 qts just to increase the level slightly above the cold mark even though the trans is up to temp. I'd like to add more fluid but I thought it might be a good idea to run this by the forum first to see if I am missing something.
The trans fluid level was nearly at the hot mark (at temp) prior to the drain and fill. Why might a simple drain and fill require more than the expected 6.5 qts? We're not talking about half a quart more....this is now approaching 2qts more than expected.
I looked under the vehicle several times since the job was finished and there's no visible leak.
Any ideas?
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8, 01 WJ Limited, 96 XJ Classic, 00 XJ Sport, 90 XJ Wagoneer, 97 ZJ Limited, 5.2, 98 ZJ Limited, 5.2
josephmartins is offline
post #2 of 12 Old 08-10-2011, 03:56 PM
MoparMan1990
1992 XJ Cherokee
i bought mine and it was low so i checked for leaks i think they changed it and it did the same thing
MoparMan1990 is offline
post #3 of 12 Old 08-11-2011, 05:21 AM
dutch724
Yup, when I changed my tranny filters the same thing happened to me. I bought an extra bottle of fluid just in case and I couldn't believe that I used that one and it still wasn't full. I had to run out and get at least 2 more quarts and I kept looking under the Jeep to see if it was leaking out. It's full now and it is maintaning it's level.
I kept questioning myself if it was a good idea to put a drain plug on the tranny pan, because I thought it was leaking thru the plug, but when I looked at the plug it wasn't wet or nothing.
Sounds like everything it normal if your having the same issue.
dutch724 is offline
post #4 of 12 Old 08-11-2011, 06:39 AM
jtcnj
jtcnj's Avatar
Wj
Mine took almost 8, maybe 7.75 after recent rusty pan replacement (no fluid leaks), but in addiiton to the 2 filters changed, I disconected the cooler lines too.
I actually undid the soft hose of the return and ran it a bit to flush it somewhat, the disconnected the feed to drain it, since the feed pumps up from the bottom of the radiator.
I read somewhere you can drain most of the converter fluid by loosening the solenoid body mounting bolts, but I didn't pursue it.
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #5 of 12 Old 08-11-2011, 07:48 AM
dutch724
I have heard the best way to get a complete tranny fluid change is to get (2) 5 gal buckets. keep one empty and fill one with the amount of tranny fluid that the tranny holds and disconnection the intake and outtake of the tranny lines going to the cooler and put the outake into the empty bucket and the intake into the bucket with all the fluid in it and start the Jeep up and it will pump out the old fluid and suck up the new fluid. When the full bucket is empty then the job is done. I would only do that if you don't need to change the filter or maybe change the filter before you start all that.
dutch724 is offline
post #6 of 12 Old 08-11-2011, 08:17 AM
WiCkeDuDe
WiCkeDuDe's Avatar
I always use 8 quarts for a drain and fill on a WJ with the 545RFE.
I Have WJ Stuff for Sale
WiCkeDuDe is online now
post #7 of 12 Old 08-11-2011, 08:27 AM
Thomahawk
Thomahawk's Avatar
2006 XK Commander
When i changed mine with both filters last time, i endes up at 7.5qt.
Buildthread
Thomahawk is offline
post #8 of 12 Old 08-11-2011, 09:21 AM
xmonger
xmonger's Avatar
2003 WJ
I might hold the record, but I had it up on the ramps for a while.
9 qts after pan drop and filter replacement
2003 WJ Overland 4.7 H.O.
xmonger is offline
post #9 of 12 Old 08-11-2011, 10:46 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
return line from the cooler returns to tank. there is no suction. you need to add through the dipstick.
ratmonkey is offline
post #10 of 12 Old 08-11-2011, 07:00 PM
straty1987
the filter hold fluid just like when you change engine oil the filter holds like half a quart.
also are you checking it on level ground?
straty1987 is offline
post #11 of 12 Old 08-11-2011, 11:34 PM
85IrocZ-28
85IrocZ-28's Avatar
When I changed my filters and installed a shift kit, I was surprised how much fluid it took...almost 8 quarts.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #12 of 12 Old 08-12-2011, 01:02 PM
Planetcat
2010 WK
The FSM says 6.6L of fluid on a drain/fill, 13.3L on an overhaul. I think I put a good 9-10 quarts in when I dropped the pan and replaced the filters. I don't know the conversion of liters to quarts, but you should be in the ball park.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
Windshield stains and Drain windshield wiper fluid-First post! rams5813 WJ Grand Cherokee Forum 7 07-22-2011 11:19 AM
About to change tranny filter/fluid Garaphin WJ Grand Cherokee Forum 13 07-07-2011 05:47 PM
Dark tranny fluid? AustinMeredith WJ Grand Cherokee Forum 2 06-25-2011 11:37 AM
Tranny fluid low novellof WJ Grand Cherokee Forum 8 10-24-2010 06:49 PM
changing tranny fluid 42RE noeffort WJ Grand Cherokee Forum 34 03-25-2010 06:55 PM
