4WD Part Time Light - JeepForum.com
post #1 of 8 Old 08-03-2020, 10:11 AM Thread Starter
TastyWheatLoaf
TastyWheatLoaf's Avatar
4WD Part Time Light
Hey folks, random thing that has been happening to me. 03 4.0 with selec-trac. When doing long stints of around town driving, my part time light has been randomly lighting up on and off when stopped at lights. When on throttle it doesn't happen. Seems to happen when it's been hot out recently too. Any thoughts?
TastyWheatLoaf is offline
post #2 of 8 Old 08-03-2020, 11:28 AM
DJCantonGA
DJCantonGA's Avatar
Not sure on that one, but have you tried shifting it to PT/FT, then back up? Just to make sure it is fully engaged in 2WD. That is my only idea.
2004 WJ-4.0 I6-42RE-278K-2.5" BB-265/65/17 Toyo Open Country 2 AT-Quadratec Hardrock Wheels
DJCantonGA is offline
post #3 of 8 Old 08-03-2020, 11:35 AM Thread Starter
TastyWheatLoaf
I'll give it a try, but yeah really weird. Like it only just started to happen and I've owned this jeep for 2+years now.
post #4 of 8 Old 08-03-2020, 11:49 AM
DJCantonGA
DJCantonGA's Avatar
Sometimes I'll have to shift back to 2wd, then back up for a few feet for it to fully disengage. Otherwise it will slip back into PT if I barely bump the shifter. Maybe it will work, who knows?
post #5 of 8 Old 08-03-2020, 01:47 PM
Oktavius
Someone may be able to correct me, but I believe the switch on the transfer case has a plunger and a spring. Maybe the spring broke or the plunger isn't moving appropriately and causing the intermittent light to kick on randomly.
Oktavius is offline
post #6 of 8 Old 08-03-2020, 02:03 PM
99wjtx
99wjtx's Avatar
Yes. Those sending units on the 242 are notoriously flakey from what I've read. I used to have the same problem with an intermittent light, which would come on sometimes when I was not in part time. I got irritated one day and crawled under the Jeep with a wire snip. No more light.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #7 of 8 Old 08-03-2020, 02:17 PM
Oktavius
I had swapped to the 242HD from a 247. I have the sensor there to plug the whole but did not see an unused plug on the wiring harness so it isn't hooked up. I also still have my QuadraDrive indicator plate on my shifter. Normally it is in Neutral which is really the 4 Full-Time, haha.
Oktavius is offline
post #8 of 8 Old 08-03-2020, 05:15 PM
99wjtx
99wjtx's Avatar
Not that I recommend hooking it up, but there should be a short pigtail dangling off the harness at the top of the trans tunnel. It's obscured by tape or loom or both. I can't remember for sure but supposedly all WJs have it. I was able to find it on my '99 and '01.
There's an impossible to find jumper harness that goes between the sending unit and that trans tunnel harness. I didn't have the jumper harness so I spliced and diced, which might have contributed to the problems I was having. I know how to spice wires though so I'm leaning toward the sending unit itself being the problem.
99wjtx is offline
