4.7V8 Turns but won't start right away - JeepForum.com
post #1 of 35 Old 11-30-2011, 06:54 PM Thread Starter
ElkGroveJeeper
I just bought this used '99 with the 4.7V8.
Just recently when trying to start it the engine turns strong but won't start right away. After about 5 seconds the engine fires and runs great until the next start-up. (Maybe we should never shut it down...)
It sounds like it's not igniting.
I thought it might be the coil, but apparently the 4.7 has individual coils, one for each plug. So, I'm doubting that would be the problem. (But maybe...)
The fuel pump is working and there appears to be plenty of fuel pressure in the log.
I checked the ASD relay and it appears to be fine as well.
I haven't invested yet in a code reader (but that will soon change).
Any ideas regarding what the trouble could be?
ElkGroveJeeper is offline
post #2 of 35 Old 11-30-2011, 06:58 PM
Rocklobster
Rocklobster's Avatar
Next time you start it turn the key to on..not start..for two seconds then turn to off then start as normal.
Have you done any maintainence lately ?
Sent directly from my brain using JeepForum
Rocklobster is offline
post #3 of 35 Old 11-30-2011, 06:59 PM
Rocklobster
Sorry.. I am thinking fuel filter needs replacing
post #4 of 35 Old 11-30-2011, 07:02 PM Thread Starter
ElkGroveJeeper
@ Rocklobster...
Re the fuel filter: That's possible, however there appears to be plenty of fuel available at the log. It certainly won't hurt to put a new filter in, though.
I tried the "turn key to ON" for two seconds procedure, but no difference. What does that do?
post #5 of 35 Old 11-30-2011, 07:04 PM
Rocklobster
That will run the fuel pump for two seconds and basically prime the system
post #6 of 35 Old 11-30-2011, 07:20 PM
Scibbyz99WJ
Scibbyz99WJ's Avatar
I had a hard start issue with my 4.0. I also had a severely outdated battery. new battery, no more hard starts
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #7 of 35 Old 11-30-2011, 07:23 PM Thread Starter
ElkGroveJeeper
@ Scibbyz...
Brand new battery. Engine is turning strong...
post #8 of 35 Old 11-30-2011, 07:30 PM
Scibbyz99WJ
darn, I was hoping it was simple. good luck
post #9 of 35 Old 11-30-2011, 08:36 PM
Rocklobster
You should check your fuel pressure while cranking to narrow down a cause
post #10 of 35 Old 11-30-2011, 09:16 PM
BigRedKM
Im having the exact same. Changed the filter. Termical connections. Battery. Did the whole key on then off then start thing. No diffrence. Only other thing wohld be the camshaft positioning sensor.
BigRedKM is offline
post #11 of 35 Old 11-30-2011, 09:22 PM
WJChris
WJChris's Avatar
When I replaced mine, my (exact same issue) did not go away.
I also already cleaned my IAC and installed new spark plugs a few months ago. Neither helped.
Im not going to worry about throwing money at it, since its more of an annoyance than anything wrong.
WJChris is offline
post #12 of 35 Old 11-30-2011, 09:57 PM
BigRedKM
It just sucks also because everyone stares at you like loom at that pos not starting. Then vroom. I always tell people before they get in " second turn always starts"
BigRedKM is offline
post #13 of 35 Old 11-30-2011, 10:06 PM Thread Starter
ElkGroveJeeper
Thanks for the input everybody.
I unfortunately don't have the time to mess with it so I'm bringing it to my mechanic tomorrow.
I'll post what the issue was.
post #14 of 35 Old 11-30-2011, 10:12 PM
IgotJeep99
Let us know what your mechanic find.
I too have a slow start.
IgotJeep99 is offline
post #15 of 35 Old 12-01-2011, 04:35 AM
kfxnando
in the exact same situation
have changed fuel filter, plugs, cleand every thing like air temp sensor idle control unit, and it still does it, have not done the fuel pump yet, however have read other pots here where even doing the fuel pump did not help, so I have held back on dropping the tank.
my one has gotten worst over time, and if the tank is bellow 1/4 and I turn hard to the right it cuts out
meantime will keep watching such threads till a solution is found or something breaks that I can say found it
WK2012 Hemi Stock
kfxnando is offline
hard start, stalls on right turns?fuel pressure only 25psi in a 1999 Jeep GCL? Frankus12 WJ Grand Cherokee Forum 2 05-16-2011 01:39 PM
rattle on right turns mattjay WJ Grand Cherokee Forum 0 02-21-2011 02:34 AM
HELP!! Jeep turns over but will not start. ODS not responding jeepers99 WJ Grand Cherokee Forum 3 04-25-2010 05:49 PM
A/C turns on when it feels like it bb1968 WJ Grand Cherokee Forum 2 03-23-2010 09:00 PM
A/C Randomly Turns On Astorm WJ Grand Cherokee Forum 4 06-05-2004 06:21 PM
