4.7 Valve Cover Bolt Size? - JeepForum.com
 3Likes
  • 1 Post By Uniblurb
  • 1 Post By HarryH3
  • 1 Post By Spyder62
post #1 of 14 Old 03-26-2020, 05:10 PM Thread Starter
Wabatuckian
Wabatuckian's Avatar
Hello,
I have a couple rounded-off valve cover bolts, and I need to replace my lifters.
Not wanting to spend $15 per bolt, and I'm sure they're of a size that can be found elsewhere.
Does anyone know the size, so I don't have to pull one and go hunting?
Thanks!
Josh
Wabatuckian is offline
post #2 of 14 Old 03-27-2020, 10:15 AM
99wjtx
99wjtx's Avatar
You're probably going to have to pull one if you can and take it with you to the hardware store. Whether or not they can be removed without first pulling the cover off I don't recall. I just remember there's some kind of mechanism there that makes pulling the bolts from the cover a real PITA. The factory parts manual says that the bolts weren't sold or stocked separately from the cover itself but I believe they can be removed.
Otherwise, if you Google far and wide long enough you may find mention of the size in a forum somewhere. There were a lot of 4.7 engines put in Dodge trucks too.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #3 of 14 Old 03-27-2020, 04:26 PM
Uniblurb
Uniblurb's Avatar
^ Yeah, no info on the WJ parts list for the 4.7 valve cover bolt size. But odd if they say it's not serviceable they do list the part number plus size for the 4.0 valve cover bolts which are likely just a different size.
Wabatuckian likes this.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #4 of 14 Old 03-27-2020, 04:56 PM
97Mule
97Mule's Avatar
How in the hell can anyone round off a valve cover bolt........
97Mule is offline
post #5 of 14 Old 03-27-2020, 04:59 PM
HarryH3
First, are you certain that the bolt threads are stripped? The bolt is steel, threading into aluminum. It's far more likely that the threads in the head are stripped out.
However, to get the bolt out to see what is really stripped, loosen the bolt until it is free from the threads. Then you can gently pull it out with a pair of pliers. It has a collar/spacer crimped onto it that sets the spacing for the gasket and prevents pressing down too hard on the valve cover. It's held in place by a rubber grommet. Because of that collar, replacing just the bolt will be tricky. You'll need to figure out a way to get it off and move it to the new bolt.
HarryH3 is offline
post #6 of 14 Old 03-27-2020, 05:02 PM
HarryH3
My guess is that they tightened the crap out of it, trying to stop a leak. But those collars stop it from going down any further.
For some reason, I was thinking stripped threads when I read the OP.
97Mule likes this.
HarryH3 is offline
post #7 of 14 Old 03-27-2020, 08:42 PM
LelandGray
Just go to the junk yard and find some in good shape..
2001 WJ Limited w/ QuadraDrive
Bilstein 5125's
jgcparts 2.5"/2" BB
JK take offs & 265/75R17's
LelandGray is offline
post #8 of 14 Old 03-27-2020, 08:42 PM
Spyder62
Spyder62's Avatar
Here are a couple I pulled off an 08 -4.7. They are 1 1/4” long not including the head. Metric #6 1.0 Not sure if you can reuse the metal sleeve from the old bolts on to the new ones. Also not sure if they are the same as a wj. Hit a junk yard! I might do the passenger side valve cover on my 04 tmoro. If so I’ll confirm the sizes
99SK04GTX likes this.
Spyder62 is offline
post #9 of 14 Old 03-28-2020, 03:56 AM
HarryH3
Originally Posted by Spyder62 View Post
... I might do the passenger side valve cover on my 04 tmoro. ...
Be sure you have a fist full of singles for the swear jar!
HarryH3 is offline
post #10 of 14 Old 03-28-2020, 08:31 AM Thread Starter
Wabatuckian
It looks like they rusted.
Josh
post #11 of 14 Old 03-28-2020, 08:33 AM Thread Starter
Wabatuckian
Some time before I got the Jeep, a couple bolt heads rusted. I don't know why. It appears that side of the engine was wet.
Josh
post #12 of 14 Old 03-28-2020, 08:35 AM Thread Starter
Wabatuckian
The local junkyard has no 4.7 Jeeps or Dodges last I checked. I'll have to call again.
Josh
post #13 of 14 Old 03-28-2020, 08:37 AM Thread Starter
Wabatuckian
Here are a couple I pulled off an 08 -4.7. They are 1 1/4 long not including the head. Metric #6 1.0 Not sure if you can reuse the metal sleeve from the old bolts on to the new ones. Also not sure if they are the same as a wj. Hit a junk yard! I might do the passenger side valve cover on my 04 tmoro. If so Ill confirm the sizes
Thank you!!!
Go slow. I already did the driver's side, and then ran into those rounded bolt heads when I went to do the passenger side.
So, I pulled the A/C to get to them. Looks like pulling the AC would be the easier way to begin with. I need a new compressor, so I just figure I'll do all that at once.
Josh
post #14 of 14 Old 03-29-2020, 08:28 AM
jtpeters
FSM states "unbolt A/C compressor and move to the side"....
2004 Jeep Overland WJ 4.7 H.O. (Bought new in Oct 2003)
2014 Jeep Overland WK2 5.7 Hemi (Bought used in 2016 w/7k miles)
1970 Ford Mustang Boss 302 (in Family since 1974)
2013 Ford Mustang Boss 302
2011 BMW 328i
jtpeters is offline
