The 4.7 Liter HO head replacement. - JeepForum.com
post #1 of 4 Old 07-20-2012, 09:02 PM Thread Starter
sthomas7mm
Wj The 4.7 Liter HO head replacement.
For those of you who own the 4.7 Liter High Output... Make no mistake this is an awesome engine with more horse power than the 5.9 Liter V8 .... but when it fails... it it can be a nightmare.
It was running great @ 120000 miles..stopped at coffee shop and upon leaving it would not start right up like usual... i cranked it and feathered the gas to get it running, it sputtered and barely got me home. I pulled up the fault codes and found a internal PCM fault code so I replaced the PCM @ $200... no change. i replaced the crank sensor and the cam position sensor... no help! I checked all 8 coils and fuel injectors, they r all fine. finally took it to suncoast Chrysler Plymouth and they told me it was the fuel injecter on #2 cyl. had them change it @ $325.oo, still wont run... Sputters and wont idle and smells like unburned fuel... they put a camera down #2 cylinder and they
said that my intake valve seat came unseated and caused catastrophic cylinder damage and i need to replace the engine @ $8988.oo.....
I took it out of there and pulled the heads and found nothing catastrophic... just a slight ding in the piston no crack and no cylinder scoring at all. the valve seat did fall out of place and was hanging on the valve. I had the folks at tiger automotive in st. pete FL get me 2 new heads for it installed
and 8 new plugs and it now runs great. runs cooler .. gets better milage .. and feels way stronger than when i first bought it...
Like i said it is an awesome engine.....when its healthy.....
1332090374421.jpg   39383064036_large.jpg   IMG_20120607_135626.jpg   IMG_20120607_135632.jpg   IMG_20120607_135537.jpg
IMG_20120607_135657.jpg   IMG_20120607_135110.jpg   1339091244902.jpg   IMG_20120607_135751.jpg   1339173930840.jpg
sthomas7mm is offline
post #2 of 4 Old 07-20-2012, 09:08 PM
Jacko84
Jacko84's Avatar
How much did the 2nd place charge?
02 WJ Limited | 4.7L HO | quadra-drive | 3" KOLAK lift: Bilstein 5100s shocks, OME HD coils | Moog steering stabilizer | JKS adjustable track bar | 245/70R17 General Grabbers | 17" JK MOABS
Jacko84 is offline
post #3 of 4 Old 07-21-2012, 02:40 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
The valve seats are a VERY common problem on the 4.7 up to 2002. $9000 is over twice as much as a decent rebuilt long block.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #4 of 4 Old 07-22-2012, 07:56 PM Thread Starter
sthomas7mm
$2800.00 to replace both heads with remanned ones...
4.7L V8 Head Gasket Replacement jaytee1456 WJ Grand Cherokee Forum 11 07-22-2015 12:46 PM
4.7 liter tapping from the head tjjk00 WJ Grand Cherokee Forum 11 07-21-2012 12:49 AM
Best Replacement Head Gasket JeepAMG WJ Grand Cherokee Forum 8 11-03-2011 07:01 PM
4.0l head gasket replacement procedure grancherkee WJ Grand Cherokee Forum 1 04-11-2011 11:47 AM
Exhaust Help after Head Replacement jaytee1456 WJ Grand Cherokee Forum 0 11-08-2010 09:43 AM
