4.7 HO Intake Manifold??? - JeepForum.com
 1Likes
post #1 of 18 Old 01-23-2020, 01:32 PM Thread Starter
2004WJlover
Why are the 4.7L HO intakes so hard to find?? Im getting a remaned 4.7HO. EVERY SINGLE engine supplier says not replacing intake manifold VOIDS warranty. Any after market places out there offer new HO manifolds? Please send link I cannot find one. MY builder will clean mine for $150 but it delays shipping a week. So it would be 3 weeks till I get my engine. Trying to beat the ludicrous Arizona heat, it starts getting hot in about a month.
2004WJlover is offline
post #2 of 18 Old 01-23-2020, 05:44 PM
smokeyyank
Good time to do a 08+ upgrade but not cheap
http://www.airram.com/parts.php?categoryid=1329
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #3 of 18 Old 01-24-2020, 06:49 AM
LelandGray
You can get an 08 manifold for $20 at your local pull-a-part.. That bracket you could buy, but I've seen some that have made their own.
2001 WJ Limited w/ QuadraDrive
Bilstein 5125's
jgcparts 2.5"/2" BB
JK take offs & 265/75R17's
LelandGray is offline
post #4 of 18 Old 01-24-2020, 07:43 AM
smokeyyank
Yes, but the catch OP needs either a "new" intake or it has to be professionally cleaned for the remanufactured warranty.
04 WJ, 4.7HO
post #5 of 18 Old 01-24-2020, 07:48 AM
LelandGray
Ahh, good point. I forgot it has to be new..
Bilstein 5125's
jgcparts 2.5"/2" BB
post #6 of 18 Old 01-24-2020, 11:59 AM
Heeps_R_Us
Heeps_R_Us's Avatar
Just get any 2004 model year manifold.
Heeps_R_Us is offline
post #7 of 18 Old 01-26-2020, 05:02 PM Thread Starter
2004WJlover
There are write ups that the HO manifold are different than standard 4.7's. They are less restrictive and breathe better.
post #8 of 18 Old 01-26-2020, 05:43 PM
smokeyyank
I know that actual intake is different but the manifold I'm pretty sure is the same. Only exception was 02 I belive. But the 04 was the same for all 4.7s IIRC.
04 WJ, 4.7HO
post #9 of 18 Old 01-27-2020, 02:00 AM
Kolak
Vendor
Kolak's Avatar
The 2002 HO manifold has shorter runners than the standard 1999-2002 4.7 manifold. Then in 2003 all WJs got a new manifold, one with even shorter runners vs the 2002 HO manifold. 2003 and 2004 model years had the same new, short runner manifold regardless of whether it's a standard 4.7 or an HO.
Heeps_R_Us likes this.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #10 of 18 Old 02-18-2020, 09:25 AM
Spyder62
Spyder62's Avatar
I found a smoking deal on 2008 intake and cams . $75 bucks and the labor to pull them. Reading what I found it’s not advisable to reuse a used intake. I guess I can pull it apart and see what took the motor out . But being a4.7 I can probably guess. If it dropped a seat or whatever. Would you guys feel safe cleaning it and reusing it?
Spyder62 is offline
post #11 of 18 Old 02-25-2020, 09:13 PM
ParkerStovall42
There is no difference between the 4.7 and the HO manifolds on the 04, they are identical. Scrub it out, put on a new gasket, and go. The warranty void nonsense is likely there to prevent warranty returns on shadetrees screwing up an install and trying to finagle a new motor. If Chrysler isn't manufacturing new intake manifolds and your warranty is void without one, I read that as 'these engines have no warranty, proceed at your own risk'.
ParkerStovall42 is online now
post #12 of 18 Old 02-26-2020, 09:50 AM
Redrider02
Is there proof that the 04 intake manifolds are identical as the 02 HO? Some say they are different.
Redrider02 is offline
post #13 of 18 Old 02-26-2020, 10:14 AM
carpentersaprn
I used to live and run in the CJ5 and CJ7 world, but then my wife found out about the WHo's and here I am, relearning everything.
My questions about these manifolds is:
1) Do the HO manifold really make a difference?
2) Is there any letter/stamping designation to signify HO.
3) What years were these manifolds used on?
Both my jeeps have the 4.7 ('99 & '00) and I'm wondering if the time/effort is worth the return.
Thanks.
carpentersaprn is offline
post #14 of 18 Old Yesterday, 10:56 AM
ParkerStovall42
The HO manifolds pre 2003 have HO embossed on the back. 2003-2004 the 4.7 was swapped to using the same 'HO' manifolds across the board. For the guy asking for proof, Chrysler parts catalogs are widely available. There is a ton of mysticism surrounding these things, I don't understand why. They're slightly shorter and slightly less restrictive so theoretically you can achieve a performance bump but it's really minor. The HO also uses a completely different resonator, and tubing between the air box, and a completely different intake box, but I never hear anyone ask about those.
post #15 of 18 Old Yesterday, 11:27 AM
99wjtx
99wjtx's Avatar
You can't disassemble these intake manifolds. Warranty issues aside, they can be cleaned effectively. I've done it. It's a process though that includes soaking, power spray rinsing, soaking, rinsing, shaking, etc., etc.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
99wjtx is online now
