4.7 HO Cam bad. Can't find replacement - JeepForum.com
post #1 of 6 Old 08-14-2019, 07:47 AM Thread Starter
rednecktrucker
I have a 2004 overland with a 4.7 ho engine. I need a driver side camshaft. Cannot find ANY!!!!
Jeep at risk of going to junkyard over an unobtainable cam. Can I get a set of non ho cams and put them in? I know I'd lose some horsepower. That's fine I just want my jeep running. Anyome help me here?
rednecktrucker is offline
post #2 of 6 Old 08-14-2019, 09:27 AM
sdg3205
sdg3205's Avatar
eBay always has HO cams, or yes, you can swap in non-ho cams, but i'd do both, not just one. I have a set of non-ho cams if u need them.
sdg3205 is online now
post #3 of 6 Old 08-14-2019, 10:00 AM Thread Starter
rednecktrucker
How much would you want for the cams?
Are you for sure they can be swapped?
post #4 of 6 Old 08-14-2019, 10:11 AM
sdg3205
sdg3205's Avatar
I'd be happy with $50 plus shipping. they have 200k miles on them, but I'm the original owner of the vehicle with every receipt for ever nut, bolt and drop of oil I've ever put into the engine.
I'm assuming they can be swapped. If you can swap from non-ho to HO, then it stands to reason you can go the other way as well. The difference is in the lobe grind. Researching that would be on you, but i can't see why not. You wouldn't get the full benefits of the HO any more, but for $50, you keep your heap out of the junk yard.
Anyway let me know!
post #5 of 6 Old 08-15-2019, 02:51 AM
Kolak
Vendor
Kolak's Avatar
I see some availability of HO cylinder heads all assembled with the HO camshaft. I can assist with that if you want to go that route. PM me here on the forum or email me at [email protected]
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #6 of 6 Old 08-16-2019, 01:31 AM
Cirruslydakota
I have two refurbished right side H.O. cams 16 new lash adjusters, and 16 new rocker arms if you need parts.
Sent from my LM-G710VM using Tapatalk
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
