4.7 Dropped Valve Seat - YEAR POLL - Page 4 - JeepForum.com
View Poll Results: What year was your dropped valve 4.7?
1999 8 11.59%
2000 10 14.49%
2001 8 11.59%
2002 19 27.54%
2003 3 4.35%
2004 22 31.88%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
 24Likes
post #46 of 171 Old 12-20-2016, 08:35 AM
BuickNut
Originally Posted by HarryH3 View Post
I've read that excessive ping/detonation can contribute to the problem as well. It makes the combustion chamber temps go way above normal. The aluminum head expands more than the steel valve seat as it heats up.
With that being said, I wonder how many H.O.s compared to standard 4.7s? Since standard 4.7 has no knock sensors compared to the H.O.s 2 sensors in the intake valley.
BuickNut is offline
post #47 of 171 Old 12-20-2016, 08:57 AM
HarryH3
Theoretically, the non-HO should be less prone to detonation since it has a lower compression ratio. The reality is that modern gasoline sucks, so it may or may not really meet the octane rating on the pump. One still has to wonder why Jeep cheaped out and left the knock sensors off of them.
BuickNut likes this.
HarryH3 is offline
post #48 of 171 Old 12-25-2016, 06:01 PM
Krwlnrx
How to you determine a dropped valve seat? Any test I can run?
2000 WJ Limited in arrest me red. :)
4.7L Quadra-Drive.
"You can go fast, but I can go anywhere."
Krwlnrx is offline
post #49 of 171 Old 12-26-2016, 03:41 AM
alfaitalia
alfaitalia's Avatar
Low compressions (not at first though), misfire (again not at first), one valve sitting lower than the others (when closed of course) when you take the valve covers off....pop the lifters off to view all at once.....and finally a horrendous misfire and rattle as the bits off seat embed themselves in your piston and head and bend the valves and perhaps escape into the inlet or exhaust manifold. That just about covers it!!!
MOTOWN and mojo509 like this.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #50 of 171 Old 01-25-2017, 11:33 AM
gvelis
2002 XJ Cherokee
2002 still going strong 287k miles!
gvelis is offline
post #51 of 171 Old 02-03-2017, 04:08 PM
sartech
1999
1999
sartech is offline
post #52 of 171 Old 04-09-2017, 07:11 PM
99WJBuild
So since I'm going to be dropping in a 4.7 to replace the blown one in my build, is there anything I can do on the front end to remedy this that would be easier with the motor on the stand? Any other items I should consider changing out with that in mind as well?
99WJBuild is offline
post #53 of 171 Old 04-09-2017, 08:34 PM
HarryH3
It would require pulling the heads. Best fix would be to take them to a machine shop and have new valve seats installed (word is that Chrysler didn't make the interference fit quite tight enough between the seats and heads on the 4.7) and also have them staked in place to make sure that they can't fall out.
I'd be somewhat concerned about just staking the factory seats, since it could deform them ever so slightly and screw up the sealing between the seat and valve face.
HarryH3 is offline
post #54 of 171 Old 04-09-2017, 10:04 PM
sdg3205
sdg3205's Avatar
It's cheaper to just install new heads. By the time a machine shop does all the labour and parts you're into those old heads for more than you'd pay for new ones with oversized seats already installed. There is an eBay seller that sells rebuilt heads for under $600.
sdg3205 is offline
post #55 of 171 Old 04-09-2017, 11:30 PM
GhostJeepWJ
GhostJeepWJ's Avatar
Mine is a 02, and the PO replaced the engine at 151k due to a dropped seat. There is currently only 20k on the reman engine. She runs strong and quiet. But this factory flaw makes me nervous and is my worst nightmare with my WJ. I've already invested a lot of money to this point and still have a good distance to go before my build is done. Would be devasting to get it close to its completion just to drop another seat along the way! So I do plan on replacing my heads once the build is near it's "end" (Jeeps are never done)
There are companies that are selling heads for the 4.7 that fixes some of the issues, such as pinning the valve seats.
Spending $600-800 for improved heads and weekend of my time is worth saving my Jeep and the headaches that would ensue if the valve seat(s) drop ruining my engine and costing $3500 to repair.
I find it even more unsettling that the 2002 model is running away with this poll!!!
It's not the Destination so much as the Journey!! - Cpt. Jack Sparrow
2002 Grand Cherokee Overland 4.7 HO
2" IRO Spring Lift w/Bilstein 5100s 245/75/R17 Goodyear Armour Shield
GhostJeepWJ is offline
post #56 of 171 Old 04-10-2017, 07:09 PM
99WJBuild
Thanks for the feedback. Much rather spend the time and money while on the stand than have it blow up in the Jeep. I will check some local machine shops just for good measure and go from there.
post #57 of 171 Old 04-10-2017, 07:34 PM
GhostJeepWJ
Some other noteworthy things to consider with the new heads.
Pinning the seats
Replacing the tensioners (check rocker arms)
And notably, there's a mod for the oil drain opening to be bigger
One company to check out is Odessa, there is another one but the name just isn't coming to me right now
post #58 of 171 Old 04-16-2017, 11:50 AM
Dag93
I haven't had a dropped valve (knock on wood) but I have had PCM issues so I would like to poll on that. 2000 4.7
If it can't be fixed with Duct tape, it can't be fixed
Dag93 is offline
post #59 of 171 Old 04-17-2017, 09:19 AM
sartech
I dont understand why it says I may not vote on this poll. I dropped a seat on a 1999 WJ. long story short, lots of money and better than new
sartech is offline
post #60 of 171 Old 04-17-2017, 01:26 PM
sdg3205
sdg3205's Avatar
i think you need more posts before you can vote.
sdg3205 is offline
