4.7 Dropped Valve Seat - YEAR POLL - JeepForum.com
View Poll Results: What year was your dropped valve 4.7?
1999 8 11.59%
2000 10 14.49%
2001 8 11.59%
2002 19 27.54%
2003 3 4.35%
2004 22 31.88%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
 24Likes
post #1 of 171 Old 08-30-2016, 10:02 AM Thread Starter
ChrisHager
ChrisHager's Avatar
We have a poll running regarding dropped valve seats in 4.7s: 4.7 Dropped Valve Seat Poll In this poll, you can vote whether or not you've experienced a dropped valve seat.
Within this thread, an interesting question was brought up:
Originally Posted by 86cj74.2L View Post
What I'm interested in knowing is if certain years were more prone than others to dropping a seat.
I'm curious now too.
If your 4.7 has dropped a valve seat, vote the year. If you have not personally experienced a dropped valve seat, please do not vote. I enabled multiple votes for those who've experienced this more than once. Let's keep the arguments to a minimum.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #2 of 171 Old 08-30-2016, 10:19 AM Thread Starter
ChrisHager
ChrisHager's Avatar
Originally Posted by Hendrix9 View Post
No offense, but since it also happens in WKs, rams, etc your year poll will be kind pointless, no?
I know the hemi's they changed the specs for how tight the seats are pressed into the heads after a certain year but i dont recall seeing that about the 4.7.
Originally Posted by ChrisHager View Post
If we are only curious about the correlation in WJs, since this is a WJ forum, then my years seem reasonable. That being said, I can easily edit in more years if everyone wishes.
Since this is a brand new thread with no votes, what's the consensus? Add more years or keep it WJ specific? I don't mind either way but would like to make changes before the poll takes off. Otherwise, the numbers will be skewed.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #3 of 171 Old 08-30-2016, 11:44 AM
sdg3205
sdg3205's Avatar
Keep it to WJs Chris. The other guys can run their own polls in the other forums.
kfxnando and 99AZWJ like this.
sdg3205 is offline
post #4 of 171 Old 08-31-2016, 02:46 PM Thread Starter
ChrisHager
ChrisHager's Avatar
I'm leaning towards WJ specific years as well. If there's mutiny, we can always create a new thread in a more appropriate area.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 171 Old 08-31-2016, 04:43 PM
86cj74.2L
86cj74.2L's Avatar
It don't need to be a perfect survey for me. I just want to see the grouping.
Just like all these PCM failures. That could be a survey. Seems like a lot of 99 and 00's.
86cj74.2L is online now
post #6 of 171 Old 08-31-2016, 05:14 PM
losttech
losttech's Avatar
99 and 2000 had a different brand of PCM from what I am told they changed it in 01 to some other vendor.
losttech is offline
post #7 of 171 Old 08-31-2016, 07:51 PM
mr312712
mr312712's Avatar
2008 WK
A 4.7 poll that I can't vote In.
Clicker01 likes this.
It doesn't matter If the guy next to you doesn't know your racing winning Is winning.
Castrol Edge 10W30 Full Synthetic
04 WJ Overland Inferno Red 4.7 MAGNUM V8 HIGH OUTPUT
mr312712 is offline
post #8 of 171 Old 09-01-2016, 11:28 PM
sdg3205
sdg3205's Avatar
You could probably vote if you drained all your coolant and raced another WK SRT8
Chris - should these polls be stickied? Otherwise they may fall by the wayside and miss voters.
sdg3205 is offline
post #9 of 171 Old 09-02-2016, 06:50 AM
losttech
losttech's Avatar
I would love to see this a sticky not sure how scientific it is but maybe a pattern could be picked up with the years.
losttech is offline
post #10 of 171 Old 09-02-2016, 07:10 AM Thread Starter
ChrisHager
ChrisHager's Avatar
I will sticky it for a little while. We try to avoid too many stickies in order to reduce clutter but I don't see why this can't be at the top for a few weeks.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #11 of 171 Old 09-02-2016, 10:37 AM
sdg3205
sdg3205's Avatar
Still only two votes!
sdg3205 is offline
post #12 of 171 Old 09-03-2016, 06:23 AM
losttech
losttech's Avatar
Maybe we just all freak out over it and its like the gas tank fires just a rare thing.
Would make me happy anyway if that was it.
losttech is offline
post #13 of 171 Old 09-03-2016, 06:48 AM
alfaitalia
alfaitalia's Avatar
The ones that will be missed are the ones that went to the scrap yard after engine failure without diagnosis. They may have thought it was another fault but it was too old and cost to much to repair. I know one that went to the breakers yard with about 200,000 on the clock. He put the rough running and low compression on number 5 down to a head gasket.... but as the Jeep was a mixture of mud and rust !!! it was not worth looking into......I think it was the dropped valve seat issue especially as three in our relatively small group have had seat drop in the last couple of years.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #14 of 171 Old 09-03-2016, 10:20 AM
sdg3205
sdg3205's Avatar
We should make another pole to get the estimated total number of active owners with both engine sizes. Of the three car forums I am a part of this one is by far the largest and most active. Polls are fun.
sdg3205 is offline
post #15 of 171 Old 09-04-2016, 06:05 AM Thread Starter
ChrisHager
ChrisHager's Avatar
Should we make a poll to see if members want to make a poll about active member's engines? Haha!
One of the most amazing things I've ever seen is people hosting meetings for the sole purpose of planning meetings. Always baffles me.
All kidding aside, feel free to make whatever poll you see fit. Worst case scenario, it will just sink it's way to the bottom. Best case, we have a sweet set of stats.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
