4.0 Crank walk - JeepForum.com
post #1 of 19 Old 04-12-2019, 05:50 AM Thread Starter
02Lightning
4.0 Crank walk
So Iíve been chasing a front belt squeal that I couldnít pinpoint until I replace my harmonic balancer and it got worse. It looks like my crank is walking maybe 3/16 of an inch and causing the belt to misalign. So my plan of attack on this is to pull the pan, inspect the thrust bearing, and hope that it has not worn into the block. My best case scenario is to just replace the main bearings, if the crank is bad then pull the motor and install a crank kit. But, if the block is bad, then I will be at a cross road if the jeep is even worth a long block. Has anyone had this problem? It has 160k on it and I bought it at 110k and religiously change the oil at 5k. Just wondering what the cause would be. Otherwise, the motor runs good with the exception of some lifter rattle at start up in cold weather.
2001 Jeep Grand Cherokee Laredo 4.0L NV242LD Transfer Case, 42RE, 160,000 miles
02Lightning is offline
post #2 of 19 Old 04-12-2019, 10:01 AM
2oldjeeps
?, not an xpert but hard to think the crank could move that much without oil problems, rods twisting and a lot of noise...double check, can you move it???
is it the pulley?
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 19 Old 04-12-2019, 11:52 AM Thread Starter
02Lightning
The harmonic balancer (and pulley is all one unit) is new, I just put it on because I thought it was separating. But, if I give is throttle from under the hood, I can see it walking away from the motor maybe 3/16".
post #4 of 19 Old 04-12-2019, 02:03 PM
FanTech
Poor surface finish on the crank can cause failures to happen faster. You could also be experiencing high line pressures in your transmission. Is there any damage to the tranny lines/cooler? Do you have an auxilary cooler? The torque converter acts like a hydraulic ram that pushes the crank forward. Thrust bearings aren't capable of handling a lot of load.
FanTech is offline
post #5 of 19 Old 04-12-2019, 03:17 PM Thread Starter
02Lightning
I put a cooler on it about a year ago and bypassed the internal cooler, i'll have to get under it and see if there is any damage.
post #6 of 19 Old 04-12-2019, 03:43 PM
2oldjeeps
gotta be the pulley not bottomed out when torqued.think about how many surfaces would have to wear to move that much without breakup!!
normal endplay is ? maybe .020 in.rods would bind or break.
did you torque the pulley bolt?
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #7 of 19 Old 04-12-2019, 04:06 PM Thread Starter
02Lightning
The old balancer walked out when I rev the motor, then after I replaced it, the new one it does the same. I replaced the seal, lubed the crank before installing the new balancer. Then torqued the center bolt to 80 ft. lbs., however I forgot the lube the bolt threads.
post #8 of 19 Old 04-15-2019, 06:55 AM Thread Starter
02Lightning
What should the pressure be for my transmission?
post #9 of 19 Old 04-15-2019, 09:31 AM
2oldjeeps
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #10 of 19 Old 04-15-2019, 10:07 AM
jtec
2014 JK Wrangler
How are you checking end play, just observing the balancer travel*?
have you dropped pan yet for a visual?
Is this the original engine -
Was there any knocking, oil pressure issue, particles in oil.
Might be my reading comprehension problem BUT I am confused as to what is issue.
Your describing moving the flywheel and converter, starter clearance issues, CKP distance, rod to piston center of piston alignment, wrist pin issue, -
OK trans pressure that varies IIRC 0 to 300 and full pressure would cause hard shifts and a pressure governor code I believe.
*Spec end play (0.0015 to 0.0065 in.) your claim 3/16 (.187) - makes me think something is missing in description.
jtec is offline
post #11 of 19 Old 04-15-2019, 12:13 PM
2oldjeeps
so i looked at my "new to me" 4.7 and the pulley/balancer wobbles!!
just have it 2 weeks so new 2 me.
how much wobble is ok?
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #12 of 19 Old 04-15-2019, 01:44 PM Thread Starter
02Lightning
I haven't put an indicator on it or anything. No oil pressure issues and nothing in the oil that I noticed last time I changed it, but wasn't looking either. The problem I'm having is belt squeal, and I happen to notice the belt walking off the tensioner as I gave it gas and making the squeal noise. I then look down and notice the balancer moving away from the motor as I gave it gas, so I changed it figuring that balancer was coming apart, but it made my belt squeal worse. New tensioner, water pump, alternator and idler, nothing fixed it. My plan was to put a rear main seal in it, so I will inspect when I get it apart. Any other ideas?
post #13 of 19 Old 04-15-2019, 04:22 PM
2oldjeeps
r m seal? is it leaking?
rms has nothing to do with movement!!
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #14 of 19 Old 04-15-2019, 07:41 PM Thread Starter
02Lightning
Yes, the rear main has been leaking for a while. I realize that would have nothing to do with the crank walking. The thrust bearing is what keeps it in place.
post #15 of 19 Old 04-15-2019, 08:31 PM
2oldjeeps
thrust bearing in back huh?
did you see this?
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
Jeep 4.0 I6 engine crank no start, no spark, no Fuel Ridettu21 Jeep CJ Forum 11 02-19-2019 03:39 PM
2003 4.0 intermittently will not crank brunnerj30 WJ Grand Cherokee Forum 12 02-18-2019 06:58 PM
99 4.0 crank sensor replacement method. frankjc WJ Grand Cherokee Forum 13 08-15-2018 03:27 PM
91 4.0 won't crank when engine cold without some starting fluid? JimE2 YJ Wrangler Technical Forum 4 03-10-2018 12:46 PM
2000 Jeep Grand Cherokee Laredo 4.0 inline 6 cylinder slow crank worthspending WJ Grand Cherokee Forum 3 11-25-2017 05:29 PM
