4.0 bottom end noise (marble sound) - JeepForum.com
post #1 of 20 Old 10-30-2014, 11:27 AM Thread Starter
Jayybirdd
Last edited by ChrisHager; 11-13-2014 at 12:39 PM. Reason: Fixed broken page from link...
Jayybirdd is offline
post #2 of 20 Old 10-30-2014, 11:40 AM Thread Starter
Jayybirdd
Could it be a sticky lifter??
post #3 of 20 Old 11-01-2014, 04:32 PM Thread Starter
Jayybirdd
My #1 spark plug was black. Could there be excessive carbon in the cylinder causing that knock.
Also under load I'm hearing pinging
post #4 of 20 Old 11-02-2014, 12:28 AM
yossarian19
If there is excessive junk in one cylinder but not the others, there a problem worth finding & fixing in that cylinder.
yossarian19 is offline
post #5 of 20 Old 11-03-2014, 04:47 PM Thread Starter
Jayybirdd
Might be from where I seafoamed it
post #6 of 20 Old 11-13-2014, 12:22 PM Thread Starter
Jayybirdd
Bump
post #7 of 20 Old 11-14-2014, 09:56 PM Thread Starter
Jayybirdd
I'm just thinking piston slap. Because the noise goes away when warm
post #8 of 20 Old 11-15-2014, 12:11 AM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
It sounds like a 4.0. lol. If it ain't loud, don't worry about it.
Idk it could be something that got loose and is vibrating against the engine block. If you want to narrow it down, use a stethoscope.
rep-tile is offline
post #9 of 20 Old 11-15-2014, 06:19 AM
dlundblad
2003 WJ
Try a mopar filter. Mine sounded about like that.
03 WJ Laredo 4.Sl0w
2" BB-Overland Skids
IPF 868 lights-197K
245/75/16 GY DuraTracs
dlundblad is offline
post #10 of 20 Old 11-15-2014, 03:21 PM Thread Starter
Jayybirdd
It's heavy knocking when cold the past couple nights until it warms up.
What would the mopar filter do? I have a purolater in right now
post #11 of 20 Old 11-15-2014, 04:14 PM
jeepyard
Say it completely goes away when it warms up? Could be a weak lifter, my 04 done this and I wound up pulling the head and putting a new set of lifters in it. Been quiet every since (knock on wood) I bought a 2000 with a 4.0 that had a broken piston that was noisy all the time, warm or cold it never went away. Had to replace the pistons to get that noise taken care of. Could try some marvel mystery oil in the oil to see if it helps. I tried a few different things in my 04 but it just never got any better and that's why I yanked the head and put new lifters in.
jeepyard is offline
post #12 of 20 Old 11-15-2014, 06:47 PM Thread Starter
Jayybirdd
That's what I'm thinking since it goes away when warm. I don't hear it while driving or reving. It's a dull knocking though and it isn't consistent. Wonder what's going on in there.
post #13 of 20 Old 11-15-2014, 08:00 PM
dlundblad
2003 WJ
Originally Posted by Jayybirdd
It's heavy knocking when cold the past couple nights until it warms up. What would the mopar filter do? I have a purolater in right now
To be honest I can't give you a scientific response. I am guessing it has something to do with the bypass inside the filter since they are different between the 2. Mine seems quieter with a Mopar filter at least. Either way, I'd ditch the Purolator. They are known for tearing at the moment.
03 WJ Laredo 4.Sl0w
IPF 868 lights-197K
post #14 of 20 Old 11-16-2014, 12:35 AM
rep-tile
rep-tile's Avatar
Not just the bypass system, it also has to do with anti-drainback valve and the media itself. They all can affect oil flow and oil pressure.
Interesting, I stopped using Puro ever since they've been selling at Walmart... sounds like they started cutting corners as I feared. They used to be very descent filters though.
I think you might be disappointed to hear that Mopar doesn't make oil filters. In fact last time I checked they were made by Purolator.
rep-tile is offline
post #15 of 20 Old 11-16-2014, 01:35 AM
1997xj5speed1
Go for a WIX or napa gold filter
1997 Jeep Cherokee Sport 4x4 4.0 Auto 160,000 miles
1997xj5speed1 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
