4.0 or 4.7 - JeepForum.com
post #1 of 18 Old 01-13-2020, 07:13 PM Thread Starter
Byron30
Byron30's Avatar
4.0 or 4.7
Shopping for new jeep wj. can’t decide if I should get one with the 4.0 or the 4.7 was hoping you guys can help me choose one.
Byron30 is offline
post #2 of 18 Old 01-13-2020, 07:32 PM
retrvrtrainer
retrvrtrainer's Avatar
What do you have planned for it, daily driver...off road?
Matt 7:7-11
retrvrtrainer is offline
post #3 of 18 Old 01-13-2020, 07:37 PM
paulvon
The 4.0 had a reputation to go on forever.
At the same time the 4.7 is sensitive to abuse and has a reputation for dropping valve seat. Read up on this issue.
If you need extra power look at the 4.7, but not then the 4.0
Sent from my SM-G920V using Tapatalk
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
paulvon is offline
post #4 of 18 Old 01-13-2020, 08:34 PM
smokeyyank
4.7HO or a 4.0 with a plan to swap axles and gears. 4.0 better engine but not my first choice for a lifted rig. 4.7 tons more power but not the best from a longevity/neediness standpoint.
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #5 of 18 Old 01-13-2020, 09:17 PM Thread Starter
Byron30
Byron30's Avatar
Both but mostly daily driving
Byron30 is offline
post #6 of 18 Old 01-14-2020, 09:01 AM
Mattyjm
Mattyjm's Avatar
I would recommend that you do plenty of research on your own and don't follow recommendations of opinionated people before making a choice.
If you don't know much about either engine, or complete powertrain packages offered with their respective engines, an opinionated forum thread is NOT the place to start your research.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #7 of 18 Old 01-14-2020, 09:31 AM Thread Starter
Byron30
Byron30's Avatar
I have 4.0 and have had a 4.7 I really like the 4.0. it is way more reliable but it doesn’t have enough power for me. do you know a simple and cheap way to get more power out of the 4.0?
Byron30 is offline
post #8 of 18 Old 01-14-2020, 11:35 AM
VNT
VNT's Avatar
I would buy whatever you find in decent condition
VNT is offline
post #9 of 18 Old 01-14-2020, 12:12 PM
Mofugly13
I chose to buy a wj with a "low" miles (100k) 4.0 because of the longevity/durability/reliability factor of that motor. My wheeling consists of rough forest service roads, so nothing hardcore for me.
Sent from my SM-G960U using Tapatalk
Mofugly13 is offline
post #10 of 18 Old 01-14-2020, 02:39 PM
smokeyyank
Gears is the only way to cure the 4.slow in the WJ. Otherwise cheap and easy...... nitrous but that's not a good choice.......
04 WJ, 4.7HO
post #11 of 18 Old 01-14-2020, 03:25 PM Thread Starter
Byron30
Byron30's Avatar
What gear ratio should I change to?
Byron30 is offline
post #12 of 18 Old 01-14-2020, 03:45 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I prefer the 4.7.
Depends on the tire size.
Wheelin98TJ is offline
post #13 of 18 Old 01-14-2020, 04:56 PM
AVR2
The 4.0 and 4.7 have almost the same awful MPG, but the 4.7 is way more fun to drive.
4.0 much more tolerant of abuse and easy to work on, but the 4.7 isn't as unreliable as often claimed. However, if you *do* get valve seat issues on the 4.7, then you can be looking at a complex and expensive fix.
AVR2 is offline
post #14 of 18 Old 01-14-2020, 06:08 PM Thread Starter
Byron30
Byron30's Avatar
32 inch tires
Byron30 is offline
post #15 of 18 Old 01-14-2020, 09:44 PM
smokeyyank
Check out the grimmjeeper.com. he had a great ratio calculator. Just going off my XJ I'd sy 4.56 or 4.11s. Will depend on what you need. I had 4.11s in my XJ with 33s and wish I had 4.56. I'm also at 7k+ elevation so that does make a difference.
04 WJ, 4.7HO
