2004 WJ Rear window rolling down? - JeepForum.com
post #1 of 6 Old 05-20-2019, 07:15 PM Thread Starter
Jeeper1970
Hi guys,
My 04 WJ 4.7HO rear driver side window rolls partially down when key on position (some times). It goes up/down easily with switches. Ideas?
Jeeper1970 is offline
post #2 of 6 Old 05-21-2019, 09:03 AM
GmanWJ
GmanWJ's Avatar
I would suspect the wiring in the rubber boot at the 1) driver's door or 2) malfunctioning door. You are going to have to look inside the boot for broken wires. Other possibility is the window regulator, although usually when they go it means 100% failure with the window just falling down and staying there.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #3 of 6 Old 05-21-2019, 07:43 PM Thread Starter
Jeeper1970
Ya, I was planning on checking the wires within the boot(s). I just thought it was weird that it would go down just part way. I would have thought a short or something similar would either stop if from working or make it go all the way down.
post #4 of 6 Old 05-22-2019, 09:31 AM
GmanWJ
GmanWJ's Avatar
Agreed, it is weird that it only goes down a little. But what else could it be? Something is pushing voltage to that circuit and engaging the regulator. That points to a short. Possibly even a grounding issue. There is a very good thread in here that can point you to all the grounding points that could use a touch-up after all these years, but not sure where the thread is right now. I think @Uniblurb wrote it? (I tried to tag him but don't think I did it right)
GmanWJ is offline
post #5 of 6 Old 05-22-2019, 11:03 AM
Uniblurb
Uniblurb's Avatar
You rang Gman? Lol, and your tagging/mention did work. It's a little difficult to find but my 'ground write-up' is in the FAQ's at the end of the 'Electrical' section.
Not sure on the rear driver's side door but it's likely the same as the driver's front door where the ground would be G301 which is the last diagram in the below section post. The location should be to the left of the front seat under the carpet on the floor or under the seat itself. But if there was problems with this ground there may be problems with other things since there's lots of things using this ground.
https://www.jeepforum.com/forum/f310.../#post39199282
Info was vague in doing ground research but there may also be a ground wire in the rear door and know there's one on the front under the inner cover.
Believe it's a good idea to check the wiring in the boots for breaks/shorts on both the front driver's door and rear one as Gman already mentioned.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #6 of 6 Old 05-22-2019, 01:02 PM Thread Starter
Jeeper1970
Thanks again guys, I will be looking into broken wires/grounds in both driver side doors. I love intermittent issues.
2004 WJ TRL HWK Build - Trails and Camping jayheats WJ Grand Cherokee Forum 69 06-10-2019 11:32 AM
Carck by rear window Jedibrad Paint and Body 1 01-15-2019 10:28 AM
Rear Window Wiper Arm Cpyle TJ Wrangler Technical Forum 1 12-09-2018 05:22 PM
Imped's 2004 TJ FOR SALE Imped Jeeps For Sale 4 03-11-2018 12:58 AM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
