2004 V8 Whining noise - JeepForum.com
post #1 of 12 Old 04-06-2021, 08:15 PM Thread Starter
Ku89
Hello all. This is my first post here. I did look around other posts to see if i could find a similar issue but couldn't. so here goes. I just bought a 2004 Jeep Grand Cherokee with a 4.7 v8 with 158K miles. i have the common exhaust manifold noise which i will soon replace but i also have a whine that goes up with revs, More pronounced at cold start. I have taken off the belt and started, to rule out the Power steering pump but makes no difference. It seems to change with RPM but quiets down when warmed up. Tranny fluid was a quart low so i topped it off. Fluid color looks good too. Does anyone have any ideas as to what it could be? I get the noise even when im not moving.
Ku89 is offline
post #2 of 12 Old 04-06-2021, 09:55 PM
GmanWJ
GmanWJ's Avatar
Vacuum leak?
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (8awg charging & backup cam)
GmanWJ is online now
post #3 of 12 Old 04-07-2021, 01:26 AM
CyrusB
most likely a vacuum leak
Sent from my SM-G975F using Tapatalk
CyrusB is offline
post #4 of 12 Old 04-07-2021, 07:08 AM
Bigrigr
Bigrigr's Avatar
These engines have a whine with them that is just normal noise. I believe it is the design of the timing chains and the overhead cams? It sounds as though it has a small supercharger on it. Are you sure you not just hearing this normal whine?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #5 of 12 Old 04-07-2021, 09:38 AM Thread Starter
Ku89
i always thought Vacuum leaks were more with hissing sound but i could be wrong. I will double check to see if i have any today. sometimes my idle goes below 400rpm. not sure if vacuum leaks have anything to do with that
Ku89 is offline
post #6 of 12 Old 04-07-2021, 09:41 AM Thread Starter
Ku89
It does definitely sound like a supercharger. My buddy has a 2000 GC with the V8 but its barely noticeable at startup, Where mine sound like a Hellcat, But quiets down after few minutes of highway driving.
Ku89 is offline
post #7 of 12 Old 04-08-2021, 10:30 AM
Bigrigr
Bigrigr's Avatar
Mine is the same way...Pull the serpentine belt off, and start it to listen. If the noise is still there, then it probably isnt anything to worry about. Spin the accessories by hand to double check.
Bigrigr is offline
post #8 of 12 Old 04-08-2021, 09:19 PM Thread Starter
Ku89
i pulled the belt off and started it. still the noise is present. would the hydraulic fan make this kinda noise even with the belt off?
Ku89 is offline
post #9 of 12 Old 04-08-2021, 09:48 PM
anotherheep
Just tell the chics it's the timing gears to hold your blower in time
anotherheep is offline
post #10 of 12 Old 04-09-2021, 07:39 AM Thread Starter
Ku89
Ku89 is offline
post #11 of 12 Old 04-09-2021, 01:26 PM
Bigrigr
Bigrigr's Avatar
Was the Hydraulic fan engaged at the time? I dont remember them making much noise. My daughter's '02 has the hydraulic, and i dont think i have ever heard it come on....
Bigrigr is offline
post #12 of 12 Old 04-09-2021, 03:17 PM Thread Starter
Ku89
i totally forgot to check that when i took off belt. i will recheck this weekend
Ku89 is offline
