2004 Jeep Grand Cherokee idling fast - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 6 Old 12-09-2019, 04:14 AM Thread Starter
Cincy71
I have a 2004 WJ that is idling fast. It is a 4.0. It doesn't idle fast when starting. Seems to be after driving for some time. Basically when it is running at normal temps. When I put it in neutral, it shoots ups between 1500 -2000 rpms. I can press the gas pedal one time and it goes back down to normal idle speeds.
I have replaced the TPS but it didn't help. Any suggestions what I should try next? Maybe IAC?
Cincy71 is offline
post #2 of 6 Old 12-09-2019, 08:14 AM
jtec
jtec's Avatar
2014 JK Wrangler
Cheap and easy things first -
Check codes even if light is off.
Tell us is AIRBAG light on?
Cleaning the IAC is always recommended - tutorials on you tube.
let us know after those trying ideas.
Cincy71 likes this.
jtec is online now
post #3 of 6 Old 12-09-2019, 12:16 PM
2oldjeeps
mine has done that,not enuf to bother,but it idles at 700,other jeeps at 4-500.
how can i move it down?
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #4 of 6 Old 12-10-2019, 09:41 PM
Waterluvr
You can't, the pcm controls idle speed via 4 driver circuits to the IAC motor with a target value of 720 rpm's.
Waterluvr is online now
post #5 of 6 Old 12-15-2019, 05:26 PM Thread Starter
Cincy71
No codes and airbag light isn't on.
I did clean the IAC though and it seems to have fixed the idling issue. It has been 4 days now since I cleaned the IAC and it hasn't idled fast since cleaning it.
Thanks for the suggestion Waterluvr. Hopefully that fixed the issue. If it starts again, I might just buy a new IAC. It looked pretty rough even after cleaning it.
Cincy71 is offline
post #6 of 6 Old 12-15-2019, 05:29 PM Thread Starter
Cincy71
Thanks jtec for the suggestion.
Cincy71 is offline
