2004 Jeep Grand Cherokee cranks but won't start - JeepForum.com
post #1 of 4 Old 06-06-2020, 02:32 PM Thread Starter
xphoidz
My sister's Jeep won't start, am I missing anything here or should I just take it to the shop? Symptoms:
Cranks, but won't start
ASD and Fuel pump relay clicking on and off (vibrating)
Things we have checked/replaced
Fuel pump getting pressure (had to bypass ASD relay)
Battery has good connection and is in good condition
Got new key made
New Preprogrammed PCM
Starter was bought last year
New Crankshaft position sensor
New sparkplugs (has COP so haven't check if it has spark)
Tried a OBD2 codereader, but stuck on reading (works fine on my car)
The only thing I can think of is maybe the new PCM is messed up. Any ideas?
xphoidz is offline
post #2 of 4 Old 06-06-2020, 02:40 PM
jtec
jtec's Avatar
2014 JK Wrangler
see other post
jtec is offline
post #3 of 4 Old 06-06-2020, 03:38 PM
speednjay
speednjay's Avatar
So you have fuel pressure at the rail on the engine?
speednjay is offline
post #4 of 4 Old 06-06-2020, 05:37 PM
Waterluvr
Waterluvr's Avatar
When I get one of these in with a crank no start the first thing I do is get the scan tool out and monitor live data and verify the pcm is getting rotation input from the crank and cam sensors.
From there make sure the ASD relay is powering up and fire both the coils and fuel injectors to verify the pcm drivers are working properly.
From there if it wont start or starts and dies after a few seconds I'll take loose an O2 sensor, starting to see more and more plugged cats due to the age and mileage with these and that usually lets them breathe enough to get started and running.
Waterluvr is offline
