2003 WJ 6cyl transmission slipping - JeepForum.com
post #1 of 4 Old 01-25-2020, 11:01 AM Thread Starter
good03jeep
Mj 2003 WJ 6cyl transmission slipping
My 03 WJ has 162K miles. The transmission intermittently slips going into 3rd gear. What happens is as speed is accelerated to around 40 mph, it does not shift, the tach spikes to 3500 as if it is in neutral. Easing off the speed most times it slips into gear, Sometimes it takes a couple times doing this. Sometimes it just shifts as is normal.
I know nothing about transmissions and the cpl of shops I've talked to have offered no explanation other than say they they have to look inside and see what the problem is and that I might need a new transmission, which I don't wish to go that expense.
The truck is very good condition other wise, Runs great, no other mechanical issues, could use shocks. Cosmetically inside and out in very good condition.
Thanks very much for you insights!
Russ
good03jeep is offline
post #2 of 4 Old 01-25-2020, 12:04 PM
tjmaximus
NeverEndingWorkInProgress
tjmaximus's Avatar
If it's the 42re transmission, which is usually behind the 4.0 it could be the speed sensor that screws into the bottom on the driver's side or maybe not! I changed it out on our '03 with an aftermarket brand (Dorfman I think) and it worked fine for bout 2 to 3 weeks then started doing that crap again. So I found a MOPAR OME VERSION that I have yet to put in because of the weather and I'm no spring chicken! Hopefully that will fix it , but who knows. Always disconnect your battery when working on electrical stuff on these things. there's a wire coming out of it you will have to disconnect, check it for frays or cuts, etc. and have a catch pan handy because about a pint of tranny fluid will run down your arm! Good Luck, Hope this fixes your problem!
White Jeep Club #44
98 TJ Sport
see profile for mods.
tjmaximus is offline
post #3 of 4 Old 01-26-2020, 02:51 AM
Swiff
I did a full transmission rebuild on the 42re years ago. They have some problems that can be fixed without removing the entire transmission. The first problem is the valve body solenoids and transducer. There is also a shift spring that breaks causing erratic shifts. There is also a clip that breaks in the overdrive housing.
The overdrive housing is not expensive to buy a rebuilt unit and can be done without removing the transmission. The valve body parts and 3/4 shift spring part can also be done without removing the transmission also. Full transmission rebuild
Derek
2k WJ Laredo - 4.0L - 42RE - Select-Trac 242 - 3.55 -
Swiff is offline
post #4 of 4 Old 01-26-2020, 09:52 AM
jtec
jtec's Avatar
2014 JK Wrangler
start simple easy
Scan for codes even if the CEL is off - a scanner is recommended for trans issues.
Fluid and filter, be sure to use ATF+4 fluid. Also check pan for debris when down.
jtec is offline
