2002 WJ Overland Transmission Replacement - JeepForum.com
 1Likes
  • 1 Post By cDee63
post #1 of 3 Old 06-23-2021, 08:08 AM Thread Starter
WJ_Paul
Wj 2002 WJ Overland Transmission Replacement
Hey guys, new member here, finally decided to join after searching the site for a while. I have a 2002 WJ Overland with a 4.7HO and 545RFE, replacing my transmission with a low-ish mileage junk yard unit from a Commander, is that a direct swap? As in torque converter is the same and the units just swap out? Just covering all my bases before i screw myself over.
WJ_Paul is offline
post #2 of 3 Old 06-23-2021, 12:33 PM
juan_carlos__007
Just compare part numbers for both cars on a parts store website if theyre the same they should interchange. There were 45rfe and 545rfe just make sure they match as well. Car-part.com might help with that too
Sent from my NX629J using Tapatalk
juan_carlos__007 is offline
post #3 of 3 Old 06-25-2021, 04:54 AM
cDee63
cDee63's Avatar
The 45RFE and the 545RFE are the same trans. The difference is the TCU software, one can turn their 45 into a 545 by swapping in a TCU from a 545 vehicle, I believe 01 and up in the GC's case.
Bigrigr likes this.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
