2001 4.7 Timing Cover - JeepForum.com
post #1 of 3 Old 10-12-2021, 04:34 PM Thread Starter
c_capp30
Are all 4.7 timing covers the same? My 2001 needs a replacement (Part# 53020793). All the ones i’ve found online are Part# 53021227AA, however they all look identical. I can’t seem to find one with the original P/N. Any feedback is greatly appreciated!
c_capp30 is offline
post #2 of 3 Old 10-12-2021, 07:22 PM
WJ60
WJ60's Avatar
Interesting..... The part number coming up for my '01 w/4.7 on Moparpartsgiant.com is 5016653AB.
The part number you're listing is for a 4.0L engine.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #3 of 3 Old 10-12-2021, 07:44 PM
cDee63
cDee63's Avatar
They changed the way they seal and the gasket used in mid 02 I believe. The older style was one big aluminum framed gasket, the cover itself is flat where it interfaces with the block. The later ones have machining done to the cover and use "o-ring" style gaskets.
The cover itself will fit either way, only the gasket style changed.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
