2000 limited pcm in 2000 laredo - JeepForum.com
post #1 of 5 Old 05-14-2019, 02:23 PM Thread Starter
brokenwj00
I have a 2000 GC Limited and a Laredo. I believe the laredos pcm is on its way out. Could i use the one in my limited? both jeeps have the 4.0 and all the same options, apart from memory drivers seat. Reason for asking is the limited is my parts rig and has a software update on the pcm, and runs beautifully. My laredo ramdomly likes to stall at lights, idle rough and die when i give it gas. Ive changed the IACV, TPMS is new as well as MAF, only thing i havent tried is the crank sensor
brokenwj00 is offline
post #2 of 5 Old 05-15-2019, 05:34 AM
wjkeith
wjkeith's Avatar
No codes with that condition? Check all related wiring and vacuum lines.
wjkeith is offline
post #3 of 5 Old 05-15-2019, 07:44 AM
Waterluvr
You can use the limited pcm in the Laredo, it will need to be flashed to work with the skim module in the Laredo if you just drop it in you'll have a crank/start/run/shutdown issue after 2 seconds run time.
Waterluvr is offline
post #4 of 5 Old 05-15-2019, 09:08 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
Assuming the parts Jeep won't be need for anything other than parts, you could swap over the SKIM, PCM, lock cylinders and keys from the Limited into the Laredo.
That will negate the need for flashing the Limited ECM to the Laredo's VIN and SKIS code.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by Jeeples
This is easily the worst post, and thread, I have ever seen in 7 years of being on JF.
Jeeples is offline
post #5 of 5 Old 05-16-2019, 08:58 AM Thread Starter
brokenwj00
No CEL, but i do plan on hooking a scanner up to it just to see if anything is stored or just not tripping the light.
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
2000 WJ Limited wont start theozsnowman WJ Grand Cherokee Forum 0 04-26-2019 08:54 PM
PCM?? Dead gauges and SKIM kdubbs46 WJ Grand Cherokee Forum 40 02-16-2019 09:47 AM
2001 Grand Cherokee Laredo 6 cyl low emissions PCM??? Jaymot WJ Grand Cherokee Forum 1 12-04-2018 12:11 PM
Will A Laredo Rear Bumper Fit A Limited? BeefyJeep WJ Grand Cherokee Forum 5 08-16-2018 08:12 AM
