12-hole Injectors + TB Port & Polish - JeepForum.com
post #1 of 13 Old 06-16-2019, 01:39 PM Thread Starter
MrBaz
INJECTORS
The factory injectors on the '04 WJ 4.7HO are 2-hole injectors. Feel free to search YouTube to see how poorly these atomize fuel.
Factory Injectors:
I tried the Bosch 12-hole injectors (280156161) but had issues with them being unbalanced - ie: not flow-matched. I had 3 normal cylinders, and 5 rich cylinders. I blame this on the vendor.
Bosch 12-hole injectors:
Sent those back and ordered the Denso 12-hole injectors (12582704). These came from a vendor with a better warranty, posted specs (265CC, flow-matched to within 2%, etc.). Put these in and had no problem after putting the PCM into fast-learn.
Denso injectors:
Compared to factory:
TB Port & Polish
Factory TB has big flat faces. These flat surfaces = turbulence. Turbulence = reduced air velocity. Reduced air velocity = restricted airflow.
Note the rough as-cast surface.
A measurement from the back of the TB shows it to be machined out to 68mm.
If you don't believe me, it is stamped right on the throttle plate.
The front clearly is not. It is more like ~66mm.
You can see the 'step' clearly.
PSA: Clean your IAC valve.
Sorry, I didn't take pictures of the process. It was tedious and annoying. I wanted to see how far I could get with just hand tools. I was going to polish everything to a mirror shine, but I was running out of time and was not satisfied with the end result. I'm going to find access to a lathe and just take it to 70mm and machine a new throttle plate.
Note the flare. This eliminates those flat faces and will facilitate airflow into the TB.
There is only a tiny step left.
2004 WJ, 4.7HO, 2 cats, magnaflow
MrBaz is offline
post #2 of 13 Old 06-16-2019, 10:29 PM
Reaper3-1A
I was actually planning this on my standard 4.7L along with an 08+ Intake, some H.O cams, and modifying a Chevy throttle body once i found the right one (I have a couple in mind) rather than porting the little 'ol 68Mil stocker. Question: Did you get the Denso's from online or from a local vendor?
If its online i was wondering if you can link them so i can get a set. I picked some of these exact same Denso 704's up from a couple junkyard Saturn'd and Pontiac's with the 2.4L Ecotec motors but idk if i can get a set new or refurbished for cheaper or the same to just flow balance the ones i have then i'd rather have the new ones instead.
~Reaper
Reaper3-1A is offline
post #3 of 13 Old 06-17-2019, 07:23 AM Thread Starter
MrBaz
I purchased the Denso's from a company off eBay. They specialize in reman injectors.
MrBaz is offline
post #4 of 13 Old 06-17-2019, 09:12 AM
sdg3205
sdg3205's Avatar
I just installed these as well. Worked well.
sdg3205 is offline
post #5 of 13 Old 06-17-2019, 04:28 PM
Reaper3-1A
Nice, ill give this a shot on ebay and get some quote to flow balance the ones i already have. Nice to see other people doing 4.7L upgrades
Sent from my SM-N960U1 using Tapatalk
~Reaper
post #6 of 13 Old 06-19-2019, 07:43 AM
Heeps_R_Us
Junior Member
Heeps_R_Us's Avatar
What kind of benefit would I see going from my factory 4 hole injectors to the 12 hole injectors?
Heeps_R_Us is online now
post #7 of 13 Old 06-19-2019, 08:24 AM
torchd
2003 WJ
Better atomization of the fuel, and maybe 1 mpg increase
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #8 of 13 Old 06-19-2019, 08:30 AM
Frambo
Was just going to ask this myself
Frambo is offline
post #9 of 13 Old 06-19-2019, 09:41 PM
97Mule
97Mule's Avatar
Using a vacuum gauge for a driving tool will also provide more mpg! Better atomization of the fuel... maybe so, but it still is a port injection engine. The fuel still has to travel into the intake port before it gets to the combustion chamber. I can see it cleaning the intake valve better! But what do i know!
97Mule is online now
post #10 of 13 Old 06-20-2019, 02:56 AM
Fzz
Fzz is offline
post #11 of 13 Old 07-01-2019, 10:59 AM
sdg3205
sdg3205's Avatar
After a few weeks I can add a few notes.
The injectors seem to break even. MPG cruising at constant speeds is considerably better but accelerating seems to consume more than previously. I still havenít run a whole tank yet to see what sort of total mileage Iím getting, but Iím not seeing the big gains some people claim to see.
I think if youíre a highway driver youíll be quite happy but around town may disappoint.
sdg3205 is offline
post #12 of 13 Old 07-01-2019, 04:25 PM
Frambo
And apart from economy, are there any performance improvements?
Frambo is offline
post #13 of 13 Old 07-01-2019, 05:09 PM
sdg3205
sdg3205's Avatar
Hard to tell because I did so many things all at once. I think the better throttle response is likely from the 70mm TB ; when you think about it, when the throttle plate opens the same amount as previously itís now sucking in more air.
sdg3205 is offline
