12.1 voltage drain - JeepForum.com
post #1 of 1 Old 04-18-2019, 12:04 PM Thread Starter
Cloak1999
12.1 voltage drain
So I have a jeep wj limited 4.7L v8 non H/O awd and I got a 12.1 voltage drain I pulled all my fuses but nothing at all but when I disconnect my fuse box under neith the hood the voltage goes back to how it should be .01 and I cant find any burnt wires inside of the fuse box when I opened the bottom panel and i took some pictures of the wires connected to the fuse box
9960_1555610602152.jpg   10032_1555610616964.jpg   10044_1555610632967.jpg   10045_1555610643879.jpg   10046_1555610655685.jpg
Cloak1999 is offline
Most valuable electrical diagnostic weapon Boojo35 YJ Wrangler Technical Forum 12 12-29-2018 04:02 PM
Renix high idle speed tquinn38 XJ Cherokee Technical Forum 11 09-09-2018 04:42 PM
High Voltage rocketboy YJ Wrangler Technical Forum 25 08-30-2018 05:12 PM
1997 XJ PCM Sensor Voltage Test ZeroFoxGiven XJ Cherokee Technical Forum 15 02-06-2018 02:34 PM
CRD cold start WK-CRD WK Grand Cherokee & XK Commander Forum 21 01-06-2018 08:16 AM
