β€˜04 Grand Cherokee idle air control valve - JeepForum.com
post #1 of 4 Old 12-09-2019, 05:53 AM Thread Starter
Ayler
I have an β€˜04 grand Cherokee overland that I inherited from my best friend who passed in April. I am having problems with a very low idle when I start it and am unable to keep it running if I take my foot off the gas upon staring. It is not throwing a check engine light, but all my research leads to an IAC valve. I do not wish to dump money into a new part to just see, as I don’t have a ton, but was curious if anyone knew if this could be the problem even if the check engine light is on?
Ayler is offline
post #2 of 4 Old 12-09-2019, 05:55 AM Thread Starter
Ayler
This has been going on for anot a month and just popped up after driving fine for months then parked for two days while I was out of town.
Ayler is offline
post #3 of 4 Old 12-09-2019, 08:10 AM
jtec
jtec's Avatar
2014 JK Wrangler
being a 04 WJ I am guessing a 4.0L -
1) start by checking and posting codes. Yes do the check even if light is off.
2) remove and clean IAC - there are tutorial's on youtube.
get back after ck codes and cleaning.
jtec is online now
post #4 of 4 Old 12-11-2019, 07:52 AM
LelandGray
My 4.7 does this. I have replaced the crank angle sensor and the camshaft position sensor. I've tried to clean the IAC valve and the throttle body, but none of that has helped. My next step is to replace IAC with a new one. If that doesn't work I guess I'll start digging into the engine grounds, I think that could potentially cause similar issues.
Mines been doing it almost two years now. At first it was annoying, then I got used to it, now I just want to drive my Jeep off a cliff... But, I know it's my fault for not fixing it sooner. Just don't really have the $ to take it to a shop and don't have the time to mess with it myself.
2001 WJ Limited w/ QuadraDrive
Bilstein 5125's
jgcparts 2.5"/2" BB
JK take offs & 265/75R17's
LelandGray is offline
