02 WJ Build (Pandemic) - JeepForum.com
 7Likes
post #1 of 40 Old 03-20-2021, 05:38 AM Thread Starter
tjdhudson17890
tjdhudson17890's Avatar
Bought my WJ a month ago at the beginning of February 2021. It is a 2002 Grand Cherokee Laredo 4.0 with 242 tcase. I plan on lifting it 6.5 inches with 33 inches tires. I have already order most of the parts and have began working on it. The WJ will be mostly a trail rig which will help keep my WK from getting beat up on too much.
tjdhudson17890 is offline
post #2 of 40 Old 03-20-2021, 05:52 AM Thread Starter
tjdhudson17890
The front spring perches are rusted out so I decided to go ahead and add a truss to it while I had the front end out to fix the perches. I didn't fill confident enough to weld it on so I tacked everything on and then took it to my local welding shop to finish it up.
underscore likes this.
post #3 of 40 Old 03-20-2021, 06:23 AM
Bigrigr
Bigrigr's Avatar
Lookin good so far...Are you planning on keeping the Dana 35 rear axle? Any plans for regearing?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #4 of 40 Old 03-21-2021, 06:56 AM Thread Starter
tjdhudson17890
Will be keeping the dana 35 with 3.73 gear ratio and adding a truss to it as well. I also have a aussie locker for the dana 35 and Torq locker for the dana 30. Would like to eventually get a ford 9 inch and regear but I have already gone way over budget.
post #5 of 40 Old 03-21-2021, 09:31 AM
Bigrigr
Bigrigr's Avatar
Well, the gearing should still be OK for 33's, just be nice to the axle shafts in the D35, as they are known to break. If it ever happens to ya, I believe they sell hardened shafts for it, but most people just upgrade the whole assembly...
Bigrigr is offline
post #6 of 40 Old 03-21-2021, 04:58 PM Thread Starter
tjdhudson17890
I debated on swapping to the 44a but ended up deciding to stick with the 35. I will mostly likely end up getting hardened shafts eventually and keep a pair of stock shafts in the jeep just in case. Hopefully the truss and not going bigger than 33s will help out with keeping it in one piece.
post #7 of 40 Old 03-27-2021, 07:10 PM Thread Starter
tjdhudson17890
Finally got the front diff painted and back in the jeep along with the front half of the IRO 6.5inch long arm lift
post #8 of 40 Old 03-29-2021, 04:44 AM Thread Starter
tjdhudson17890
I installed the rear half of the lift today along with Firestone Mt2 tires. Still have to do final adjustments and do an alignment. Also need to install SYE and order front and rear driveshafts.
post #9 of 40 Old 03-29-2021, 04:55 AM Thread Starter
tjdhudson17890
Here is a picture of my fuel tank tuck which I tucked 6 inches and the winch mount I built. I did these shortly after I bought the jeep. I still need to trim the 2x3s on the winch mount and cap the ends.
post #10 of 40 Old 03-29-2021, 09:28 AM
Bigrigr
Bigrigr's Avatar
Man, its lookin awesome. Those IRO control arms really open up the place, looks like there is twice the room under the Jeep now. Everything is easy to get to. I am still debating on the tank tuck myself. I like the added room for the spare, or tools, or junk...But i hate the way the tank looks, hanging down....
Bigrigr is offline
post #11 of 40 Old 03-30-2021, 04:54 AM Thread Starter
tjdhudson17890
Yeah its coming along nice. I'm glad to have it back on the ground, been sitting in the same spot for over 3 weeks. Still have a few thing to finish up before I can take it on a real drive. I tried to leave a little storage above the tank but lifting it 6 inches and then mounting the canister above the tank took any storage options out of the picture.
post #12 of 40 Old 03-30-2021, 06:21 AM
Bigrigr
Bigrigr's Avatar
So, just curious, Did the IRO kit come with the second steering stabilizer for the drag link? Or did you add that yourself?
Bigrigr is offline
post #13 of 40 Old 03-31-2021, 06:06 AM Thread Starter
tjdhudson17890
The IRO lift kit doesn't come with second steering stabilizer. You have to purchase it separately from them. They sell a heavy duty stabilizer to replace the stock one and a dual stabilizer kit to either add a second one or relocate the lower one up higher.
post #14 of 40 Old 03-31-2021, 08:10 AM
Bigrigr
Bigrigr's Avatar
Got it, just curious. If was gonna add a second one, Thats exactly how I would do it.
Bigrigr is offline
post #15 of 40 Old 03-31-2021, 12:00 PM Thread Starter
tjdhudson17890
If you want to add a second one you would buy the dual stabilizer kit. It will come with a heavy duty stabilizer and the hardware to connect it form drag link to track bar frame bolt For the IRO track bar and most other track bars. If you have a JKS track bar make sure to click the JKS box when purchasing and it will come with hardware to connect it to the track bar itself and to drag link.
