02 vs 03 4.7 in wj knock sensors I'm putting a non ho into a overland that came with - JeepForum.com
 2Likes
post #1 of 79 Old 02-21-2020, 09:43 AM Thread Starter
Livewire9
Livewire9's Avatar
sensors?
Livewire9 is offline
post #2 of 79 Old 02-21-2020, 09:47 AM Thread Starter
Livewire9
Livewire9's Avatar
Knock sensors . can I just use the ones in my ho? Or do the non ho have them as well? & will just plug & play ?
post #3 of 79 Old 02-21-2020, 10:32 AM
sdg3205
sdg3205's Avatar
the regular 4.7 doesn't use knock sensors.
sdg3205 is offline
post #4 of 79 Old 02-21-2020, 11:42 AM Thread Starter
Livewire9
Livewire9's Avatar
So they will talk to my 03 Ho pcm ? And work no need to take the ones out of my bad ho motor?
post #5 of 79 Old 02-21-2020, 11:49 AM Thread Starter
Livewire9
Livewire9's Avatar
Looks like from my research they do in 02..4.7 I'll look a lil closer thanks.
post #6 of 79 Old 02-21-2020, 07:55 PM
sdg3205
sdg3205's Avatar
If youíre putting a non-HO into an HO rig, you need the PCM because it will be monitoring fuel grade. The fuel management between the two is different.
Hereís what I have gathered:
HO into a non HO:
Option 1 - drop in the HO engine, DO NOT use the HO PCM and simply run high octane to avoid fuel management issues. Some people report running non HO injectors is better.
Option 2 - use the HO PCM, harness and SKIM module for full HO flexibility and the ability to run 87 octane fuel
Non HO to HO
Youíd need the skim, PCM and harness because the computer is looking for knock sensor info and the fuel management is different
Someone correct me if Iím wrong
Wabatuckian and Bigrigr like this.
sdg3205 is offline
post #7 of 79 Old 02-22-2020, 09:56 AM Thread Starter
Livewire9
Livewire9's Avatar
Hi again & thank you for the insight so the 02 non H 0 motor will be going in to the Ho wj I wanted to use the complete exiting harness sensors & intake 4 & on the non ho motor just using the bare minimum from the 02 can I just mount the knock sensors on it ? & skim ? Where is it . any & all help greatly appreciated.I know im kinda going backwards in hp. Plan on rebuilding the ho if possible down the road.. I just need to get rolling again asap..
post #8 of 79 Old 02-22-2020, 10:26 AM
sdg3205
sdg3205's Avatar
I canít reply directly to your PM.
Again, Iím no authority on this but my research seems to indicate you need the PCM, harness and skim from your 02. You canít add knock sensors to a non ho because it doesnít have bungs in the heads for them.
sdg3205 is offline
post #9 of 79 Old 02-22-2020, 10:36 AM Thread Starter
Livewire9
Livewire9's Avatar
Trying to figure out how to accept directly ?
post #10 of 79 Old 02-22-2020, 10:42 AM Thread Starter
Livewire9
Livewire9's Avatar
Cpuldent I just mount them some how / where so the pcm reads them as there rather than not ? Seams like that would get me by ? Makes sence to me but ..I'm no authority on jeep electrics. I'm just a electrician
post #11 of 79 Old 02-22-2020, 03:28 PM
Bigrigr
Bigrigr's Avatar
I think you are saying to just plug the knock sensors into the harness and leave them hanging. Just to let the PCM think all is well with them, correct? I have never seen anyone do this, but i like your thinking out of the box. It would be good to know if this works, but you may have to be the guinea pig to find the answer for us....Good Luck?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,3"BBfront,2"BBrear,JK'sW/32's
Bigrigr is offline
post #12 of 79 Old 02-22-2020, 03:28 PM Thread Starter
Livewire9
Livewire9's Avatar
The 01 4.7 does have the knock sensor nubs guess it's my lucky day short of doing this in 30* weather and imtermitant snow flurries with sunshine.
post #13 of 79 Old 02-22-2020, 03:29 PM
Bigrigr
Bigrigr's Avatar
Is there just a pipe plug or something in there now?
Bigrigr is offline
post #14 of 79 Old 02-22-2020, 03:30 PM Thread Starter
Livewire9
Livewire9's Avatar
Maby easier to just volt them to the two big studs comming out of the block.. Was my first idea .
post #15 of 79 Old 02-22-2020, 03:42 PM Thread Starter
Livewire9
Livewire9's Avatar
Just the nubs not sure if they are thread as yet ? Hopefully iv read where Some 02 non ho blocks have them. makes sence or in just lucky today defiantly can use some . but what a big pita### doing this 2&1/2 times in my car port
