02 sensors - CA emissions - JeepForum.com
post #1 of 4 Old 08-19-2018, 08:58 PM Thread Starter
Motorcharge
Motorcharge's Avatar
I'm probably tired and overthinking this, but are these all 4 o2 sensors for a 4.0 on a 99 with CA emissions?
Probably don't need to replace them all but at 280k miles it's probably not a terrible idea to replace all 4.
Throwing a P0171 code. Runs great, but idles like crap, black soot on the tailpipe and I'm only getting like 9-10 mpg.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #2 of 4 Old 08-20-2018, 01:44 AM
Kolak
Vendor
Kolak's Avatar
You can see all the correct OE part numbers here:
http://www.wjjeeps.com/oxygen.htm
And you can see the list of fault codes here:
http://www.wjjeeps.com/faultcodes.htm
P0171 is "system too lean" and that could mean a lot of things including sluggish O2 sensors. You may also want to check fuel pressure and do a visual check of the sparkplugs to see if any of the cylinders look like there's mixture issues.
If the fuel filter and sparkplugs haven't been changed in a long time this would be a good time to do so.
If you do change the O2 sensors, I recommend genuine Mopar only. There are just too many issues with aftermarket sensors.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 4 Old 08-20-2018, 06:12 AM Thread Starter
Motorcharge
Already checked the other stuff. I'm not spending $400 on sensors for a $900 beater.
|SOLD|
| June 2015 COTM |
post #4 of 4 Old 08-20-2018, 08:58 AM
Soem0
Soem0's Avatar
You can find the mopar ones online for better prices than the stealership usually. You are running the risk of the new sensors. It working well if you use the after markets. Lots of vehicles are becoming more and more like this.
Soem0 is offline
