02 Jeep Grand Cherokee makes binding/grinding noise from diferential. - JeepForum.com
 2Likes
  • 1 Post By SD Overland
  • 1 Post By ChrisBro
post #1 of 12 Old 12-09-2019, 11:12 PM Thread Starter
ChrisBro
Hi everyone in JGC land. I have a 2002 JGC that started making a bindind / grinding sound when making slow left or right turns which seems to be coming from the rear diff. Once I straighten out the noise is gone. I recently changed the rotors, brake pads, shocks and diff fluid. I have not added a limited slip friction modifier yet but am hoping this will solve my problem.
Any advice would be greatly appreciated.
Thank you.
ChrisBro is offline
post #2 of 12 Old 12-15-2019, 10:58 AM
Photoweborama
Photoweborama's Avatar
Yes, the friction modifier will fix it. If itís the Chrysler stuff, dump the whole bottle in..
Sent from my iPad using Tapatalk
Photoweborama is offline
post #3 of 12 Old 12-15-2019, 01:28 PM
GmanWJ
GmanWJ's Avatar
If you have limited slip diff, the friction modifier is not optional. Add it, let it work in, noise should go away.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #4 of 12 Old 12-15-2019, 01:34 PM
SD Overland
SD Overland's Avatar
The WJJeeps website pretty much has you covered. There are specific amounts of friction modifier to add, depending on your axle, in order for it to work properly.
http://wjjeeps.com/service/maintenance_wj.htm
Buy this and add it in.
https://www.amazon.com/Genuine-Mopar...d+%2Caps%2C195
wildbill23c likes this.
* 2004 Overland 4.7 HO, IRO 3'', Billstein 4600's, BFG AT K02 245 70R17 *
SD Overland is offline
post #5 of 12 Old 12-16-2019, 02:16 PM Thread Starter
ChrisBro
Originally Posted by Photoweborama View Post
Yes, the friction modifier will fix it. If it’s the Chrysler stuff, dump the whole bottle in..
Thank you for your response, I really appreciate it. I have since added the FM and noise is gone. Thanks again.
SoCal2004wj likes this.
ChrisBro is offline
post #6 of 12 Old 12-16-2019, 02:17 PM Thread Starter
ChrisBro
ChrisBro is offline
post #7 of 12 Old 12-16-2019, 02:18 PM Thread Starter
ChrisBro
http://www.amazon.com/Genuine-Mopar-...d+%2Caps%2C195
ChrisBro is offline
post #8 of 12 Old 12-16-2019, 02:30 PM Thread Starter
ChrisBro
02 Jeep Grand Cherokee 4.7l H.O
Hi everyone, my jeep is leaking transmission fluid from where the tranny meets/mounts to the motor. I did notice that after replacing my radiator i had connected my transmission cooler lines backwards on the radiator but have since fixed this. Im hoping that it would help with the leak but i guess time will tell. If anyone knows of why else it could be leaking please let me know.
Quada-drive all-time all wheel drive.
4X4
Thank you.
ChrisBro is offline
post #9 of 12 Old 12-16-2019, 02:41 PM
GmanWJ
GmanWJ's Avatar
4X4
Thank you.
Are you sure it's transmission fluid and not motor oil? The rear main seal is back there and likes to spring leaks after 15 years.
GmanWJ is offline
post #10 of 12 Old 12-16-2019, 03:23 PM Thread Starter
ChrisBro
It's red so I'm assuming it's transmission fluid.
ChrisBro is offline
post #11 of 12 Old 12-16-2019, 03:44 PM
wildbill23c
Front transmission seal, or torque converter leaking would be my assumption...possibly a transmission cooler line leaking but I think those lines enter and exit the transmission from the passenger side.
wildbill23c is offline
post #12 of 12 Old 12-16-2019, 03:59 PM Thread Starter
ChrisBro
Here is a picture of the fluid color. I was just under there with the Jeep on and it is dripping pretty bad when it's on but stops when it's off.
ChrisBro is offline
